startup rattle
Old Sep 3, 2014 | 12:10 PM
magnum454's Avatar
Cool startup rattle
2000XK8 56000mi. On startup I now get a very short rattle. I had the secondary tensioners replaced abt 2000mi. ago. Now what?
Old Sep 3, 2014 | 12:16 PM
Gus's Avatar
Gus
It could be a number of things so see if this is what you are hearing. You will find 2 video links for this problem.
Old Sep 3, 2014 | 12:29 PM
RJ237's Avatar
Could also be the primary tensioners, or the bolts holding the secondaries are not tight. If the long bolts were reused it should have started making noise right away.
That's the trouble with having some one work on your car, you can never be certain.
Old Sep 3, 2014 | 12:36 PM
magnum454's Avatar
He was an expert Jag guy and has done 100's of these. He did use new bolts (at least I paid for new ones). The rattle just started.
Old Sep 3, 2014 | 12:45 PM
magnum454's Avatar
Also, can the primary tensioners do the same damage as the secondaries?
Old Sep 3, 2014 | 02:01 PM
RJ237's Avatar
From all I have read on the forums, the primaries are not likely to cause major engine damage. I'm sure you will continue to locate the source of the sound, and my next thought is to remove the fuel injection fuse, turn the engine over to build up oil pressure, the quickly replace the fuse and start. It may not be conclusive, but if there is no rattle it does make one suspicious that chain tensioners are involved.
Old Sep 5, 2014 | 02:21 AM
sheddist's Avatar
Had a similar issue. Noise could have been chains which had been replaced, gearbox or???
Turned out to be a catalyst falling apart.
Diagnosed by resting a bar against the engine/gearbox/catalyst and the mk1 ear.
Old Sep 5, 2014 | 05:53 AM
P700Dee's Avatar
As you have an 8 is may just be the VVT valves clicking until the oil gets to them
Dutch xjrdiamond
Nov 30, 2019 09:14 PM
Chuck Schexnayder
33
Oct 24, 2015 10:20 PM
redxk8
Oct 4, 2015 08:28 AM
inactualis
Oct 2, 2015 11:13 AM
millertic
Sep 30, 2015 08:11 PM
