Steering exit and entry.
Old Jul 16, 2014 | 05:33 PM
Loxmth's Avatar
Default Steering exit and entry.
When I put the key in the ignition the wheel should go down but it doesn't always. When I try to put it down with the switch on the column it takes two or three tries before it goes all the way down. Any ideas?
Old Jul 16, 2014 | 08:28 PM
Beav's Avatar
Join the crowd. Annual dues, payable to me, $200/year. ;-)
Many have written the same, some have written fixes but I have yet to read anyone absolutely, 100% fixing the issue.
Old Jul 16, 2014 | 08:38 PM
motorcarman's Avatar
I have replaced DOZENS of tilt motors (mostly in warranty) and all that is required is a new tilt motor assy.
I'm sure the dealer has them or can order them.
If it is too pricey then just do what most people do................. put the switch to OFF!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!
bob gauff
Old Jul 19, 2014 | 12:08 PM
Beav's Avatar
Well, there ya go. Bob, you are the first person I've seen come out and say that is the bonafide fix - thanks!
Old Jul 19, 2014 | 12:54 PM
test point's Avatar
Beav,
Did you ever get your 'reach' motor solution working and more importantly get it documented so I can fix mine?
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
jluckcuck
Nov 6, 2015 07:49 AM
Delta66
Oct 4, 2015 05:40 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
