steering pump removal
Old Mar 25, 2015 | 03:38 PM
Autobahn kid's Avatar
Default steering pump removal 03 xk8
Would anyone have a pdf file on removing the power steering pump on a 4.2L xk8?
I am attempting to fix a 2003 and a friend next door is replacing leaky seals on his front timing cover.
Both of us are stuck at the pump removal. It seems that the pump's mounting bracket bolts go into the timing cover.
thank you
Old Mar 26, 2015 | 09:17 AM
RaceDiagnostics's Avatar
I had a look at my pdf (too bid to post), it just shows two bolts on the top and two below, it just says, "remove the bolts".
dsnyder586
Dec 29, 2024 07:39 PM
Dicque
Sep 19, 2015 12:53 PM
sogood
Sep 15, 2015 07:35 AM
kstevusa
Sep 7, 2015 01:12 PM
AL NZ
Sep 4, 2015 08:39 PM
