Steering Wheel Adjustability....
Old Dec 20, 2018 | 08:53 AM
Jon89's Avatar
Default Steering Wheel Adjustability....
Took my wife's 2006 XK8 out for some regular exercise this morning. I can move the steering wheel in (towards me) and out (away from me), but the up and down movement control is not functioning. What is the usual suspect in this case?
Old Dec 20, 2018 | 09:06 AM
fmertz's Avatar
Is it off completely, or does it move one short bump at a time? Alternatively, have you tried to repeatedly activate the up or down knob to check for movement? How about the memory function? The term to search for is "tilt".
There are basically 2 "fixes" to the bump-bump problem:
  1. As the variable resistors measuring the tilt position get "dirty/greasy/off", they need to be cleaned out. Apparently, this "repair" works, but only for a while.
  2. For a not-completely-understood reason, cutting off a wire (blue?) to the tilt motor harness restores the working order of the tilt function. (I have opted to do this a long time back).
Old Dec 20, 2018 | 09:33 AM
Jon89's Avatar
When I attempt to move the steering wheel either up or down using the control knob, the motor will engage for one short "bump" in either direction, then stop. That is all I get. Attempting to replicate a "bump-bump-bump-bump" sequence to get additional movement does not work....
How do I access that "blue wire" in order to cut it or remove it?
Old Dec 20, 2018 | 11:10 AM
astromorg's Avatar
All the details are here
https://www.jaguarforums.com/forum/x...light=solution
It's actually a White/Blue wire, easily identified once the cover is off.
Glad to hear yours continues to be reliable Fmertz, as is mine. Three and a half years now!
Old Dec 20, 2018 | 12:10 PM
Jon89's Avatar
Thanks guys. I will dig into your snip-a-wire fix sometime during the holidays. I will then report back as to whether or not it worked for me....
Old Dec 20, 2018 | 06:19 PM
thom4782's Avatar
Here's what I have heard. Others may be more knowledgeable.
The tilt motor has a built in safety feature that when it encounters resistance it turns the motor off so it doesn't overheat. This causes the wheel to stop moving. Cutting the blue white wire seems to disable this feature. Perhaps the bump, bump, bump stops for a bit of time, perhaps not. Concern is that the motor overheats and causes other, collateral damage.
I just faced this problem and fixed it by replacing the tilt motor itself. It was a bit price, but voila, no more sticking.
Old Dec 21, 2018 | 08:11 AM
astromorg's Avatar
You'll see that I covered this in Post #5 in the thread at the link above. Even a full stall of the tilt or reach motors does not cut the power to them, whether the feedback wire is connected or not.
carzaddict
Aug 24, 2016 03:35 PM
bullittandy
Jul 10, 2016 02:31 PM
weisberg
Nov 4, 2014 08:46 PM
Innovative Detailing
Detailing / Car care
Dec 6, 2010 05:02 AM
chupacabra
Jul 16, 2010 04:53 AM
