Steering Wheel Drop Down
Old Jan 21, 2009 | 06:19 PM
Brutal's Avatar
Default RE: Steering Wheel Drop Down
YOU ARE AWARE YOU HAVE TO HOLD THE MEMORY POSITION 1 OR 2(WHATEVER YOURE SETUP ON) TILL IT STOPS MOVING ON XK'S..BUT IF YOUR TALKING ABOUT THE AUTO FEATURE FOR EASY ENTRY EXIT, THEN MOVE THE JOY STICK ON THE SIDE OF COLUMN FOR THE TILTUP AND DOWN QUICKLY TO CLEAN THE INTERNAL SWITCH CONTACTS, AND THAT SHOULD FIX IT FOR YOU. THEY JUST BUILD UP DIRT, CORROSION FROM LACK OF USE
Old Jan 22, 2009 | 02:56 AM
nickmd's Avatar
Hi
My XKR does this if I have not used it for a while.
If what the other guy says does not work you may have a slight battery drain, or your battery may be on the way out, which would account for it working OK for the rest of the day once the battery has had a boost
Old Jan 22, 2009 | 11:19 AM
Spurlee's Avatar
I've been systematically hitting my switches, etc. with contact cleaner. They are pretty easy toease apart and I've saved hundreds of dollars by cleaning rather than replacing.
Old Jan 24, 2009 | 05:59 PM
hlgeorge's Avatar
Spurlee, Can you explain this procedure in detail? I am having the same issue.
99xk8guy
Sep 29, 2025 10:51 PM
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
Richard_gib
Sep 12, 2015 07:08 PM
Burdedw
Sep 12, 2015 10:39 AM
