Strange Door lock problems.
Old Jul 10, 2021 | 07:31 AM
Pistnbroke's Avatar
Default Strange Door lock problems.
When locking on the remote the passenger door lock bounces before settling in the lock position. The driver's lever does not move through the actuator can be heard bouncing to match the passenger door. The cable does not seem to be broken as it will let you open the drivers door .
Suggestions and how do you get the driver's door lock out to check? repair ?
Car will not lock the drivers door on remote. Done hard and soft reset and battery is over 12.6
Old Jul 11, 2021 | 10:15 PM
DavidYau's Avatar
Default Door latch removal- Youtube video by Rev Sam
Our previous forum member has this Youtube video that may help you.
https://m.youtube.com/watch?v=DV1hy3AYni0&t=345s
Rev Sam did make a mistake in breaking the vertical link. Just push down the cover and this reveals a joint.
Its probably the micro switches within the latch unit which is a cheap but tricky replacement. The micro swotchs lever arm has to be twisted to exactly the right angle
Old Jul 12, 2021 | 12:40 AM
Pistnbroke's Avatar
Thanks for that I will look at the video. I have the lock out but it has 4 microswitches ..from what you say its the one with the lever arm on it. PS you move the black sleve upwards on mine to release the link.
You take the lock out the bottom of the door .I seen one guy struggle to get it out the top hole.
What I need now is a video on replacing the micro switch.
Old Jul 12, 2021 | 01:21 AM
DavidYau's Avatar
Not sure if there's a video, but the thread below, by scardini1 is very comprehensive.
https://www.jaguarforums.com/forum/x...-guide-185085/
Old Jul 12, 2021 | 01:24 AM
Pistnbroke's Avatar
Excellent will have a look..intend to fit the lock "externally" see what it does ..strange thing was while the passenger door handle was making it 5 movements the drivers door handle did not move . We will see.
Old Jul 12, 2021 | 07:35 AM
Pistnbroke's Avatar
Having tested unfortunately it was the actuator bit that was faulty but I found a replacement lock unit at 33....anybody want some micro switches (new) I ordered 3 ..
Old Jul 12, 2021 | 08:15 AM
Jon89's Avatar
Hang onto those microswitches. You will eventually need them....
Old Jul 15, 2021 | 06:31 AM
Pistnbroke's Avatar
Well not so simple ...originally the passenger door was bouncing while the drivers door did nothing...solenoid faulty .
So I ordered the lock from an XJ8 which has the same solenoid and swopped them. Checked the switch on the slidy bit was being operated and re fitted it all .
The move to P or R works the locks as normal.
Using the remote cause the locks to bounce but they stop in the requested position.
So having had a 4 day marathon on this I put the door card back to await your advice I suspect its not operating the slide switch early enough in the travel... Thoughts?
PS just tried the WD40 trick and it reduced the cycles from 7 to 2. I think the travel of the solenoid without load is sufficient to work the switch but with the load its not . The reduced friction allows more/sufficient travel.
Pistnbroke
Jul 10, 2021 09:45 AM
Simon 63
Nov 15, 2020 03:36 PM
1JerryL
Jan 5, 2018 09:08 AM
Anchor2
Aug 31, 2016 08:30 AM
