Subwoofer installation
Old Nov 7, 2012 | 06:13 PM
PacoXKR's Avatar
Default Subwoofer installation
Hello,
I've just bought a used 2005 XKR, and looking at the audio equipment I have discovered that there is any subwoofer in the rear shelf, there is only a pad that covers the hole. (but I thought that there were a subwoofer because the bass is very good...)
I'm thinking to install a subwoofer following some recommendations in several posts, but, does anyone know if there is a wiring pre-installation in the car ?
Paco
Old Nov 8, 2012 | 10:55 AM
Jochem00's Avatar
Yes, the pr wiring is there, but it is not connected to anything.
You can opt for going for the oem woofer from jaguar which is only 180 euros and will be a direct fit.
You still need to connect an amp
Old Nov 8, 2012 | 02:14 PM
PacoXKR's Avatar
Then the connector is in the boot near the subwoofer area and ready to connect the amp?
And is this wire connected in the other end to the main unit in the pre-amp signal output ?
Old Nov 9, 2012 | 01:52 PM
Jochem00's Avatar
Yes the subwoofer wire and connector is already next to the hole under the shelf. This cable runs towards the multi connector underneath the armrest, but that is it.
Better to run new cables
There is no pre out but you can connect an aftrmarket amp to thespeaker outputs of the radio. Put 3 ohm resistors in series and a6 ohm resistor in parallel to get the voltage down to suit the line input.
Old Nov 10, 2012 | 04:08 AM
The_Ikon's Avatar
Good info
dsnyder586
Dec 29, 2024 07:39 PM
philwarner
44
Nov 5, 2024 06:29 PM
Majik Lasers
Aug 2, 2024 01:49 AM
Dagny
Jun 11, 2024 01:06 PM
AL NZ
Sep 4, 2015 08:39 PM
