Suggest a LSD for the XKR?
Old Apr 27, 2021 | 09:19 PM
  #41
ccfulton's Avatar
That is correct, ratio is unchanged.
Old May 21, 2021 | 12:04 AM
  #42
MaxTorq's Avatar
Charlie,
would you know of someone ?
If I get my hands on a quaife ... who, in the states, could the components be sent to for a quality & proper install/set-up ?
curious max & XKRFACE
Old May 21, 2021 | 10:13 AM
  #43
Markel's Avatar
There was a time in years gone by when I could have recommended some very good LSD
Old May 21, 2021 | 11:10 AM
  #44
ccfulton's Avatar
Originally Posted by MaxTorq
Charlie,
Anyone with experience building diffs and properly setting them up should be able to do the work, there is nothing too magical about it, just takes some care and knowledge to set the lash properly.
I had mine done in Tucson at a place called Falconworks. Also had the ring and pinion shot peened and nitride coated while they were out.
Old May 22, 2021 | 03:57 AM
  #45
avos's Avatar
It has to be done right, and to set the lash properly you also need to have the right shims, not everyone has these ones. Also you have to take the diff apart again when the its not right, so here and with the shims one could take shortcuts.
That happened to me when I bought a diff in the UK with the Quaife in it, took less that 6K miles and the diff was shot.
Falconworks seem to do it right, so at least one address in the states.
Jasesonix
UK & Eire
Sep 20, 2019 10:43 AM
Frog
Oct 27, 2013 11:22 AM
gwagner
May 13, 2013 07:29 AM
Bruce H.
Oct 16, 2011 12:11 AM
jleuz1
Dec 16, 2010 12:07 PM
