Super Chillers for XKR
SteveM, I am ready to order my catch can as well. Could you tell me what bracket you ordered for your XJR? I have a 2000 XJR, so I would assume they would need the same bracket. Did you get the inline check valve, or just use the restrictor in the part load hose only? Thank you, Louis
Don't remember which bracket, probably the standard. They sent me two brackets. Doesn't matter, since they're not Jaguar specific brackets. Or maybe I just didn't see a way to use them. I made a quick bracket of my own. You could bend one of their brackets to make it work. I believe RX was working on a Jaguar application but don't know if they offer it yet.
Are you using it for the part load breather? I got the one with the single check valve. If for the full load breather than you would not want any check valves because the air needs to flow both ways.
aarahim
Aug 31, 2021 11:04 AM
metalmarty
Sep 11, 2015 07:05 AM
