View Poll Results: Have you changed your supercharger oil?
No
27
77.14%
Yes DIY before 80K
11.43%
Yes at shop before 80K
0%
Yes DIY after 80K
8.57%
Yes at shop after 80K
2.86%
Voters: 35. You may not vote on this poll
supercharger oil change kit
Old 07-22-2012, 04:55 AM
plums's Avatar
Received 2,170 Likes on 1,613 Posts
Originally Posted by steveinfrance
That's it in a nutshell - the US guys don't know they're alive. I can't get Pentosin for the roof pump and as for supercharger oil - will cold pressed extra virgin olive oil be OK?
Seriously has anyone found a suitable oil in Europe?
Do they market any of the US GM supercharged models in Europe? They would have to stock it since they consider SC oil changes to be a maintenance item as opposed to sealed for life.
You might try finding a seller on the ebay.com US web site that will ship to the EU. Always tell them to ship via USPS to avoid the outrageous customs brokerage fees imposed by private carriers.
Have you seen the price of good olive oil in the colonies?
steveinfrance (07-22-2012)
Old 07-22-2012, 05:03 AM
steveinfrance's Avatar
Plums - I'd happily swap litre for litre olive oil for pentosin or s/c oil.
Excuse my (usual) ignorance but GM is Chevrolet isn't it? Can anyone name a s/c GM car?
-although the name may also be changed for the European market.
Old 07-22-2012, 05:47 AM
Jochem00's Avatar
Vegetable oil is very good, problem is that it doesn't last long.
You can get the supercharger oil at BMW for the mini cooper s if you like. I believe peugeot has a superchaged car as well.
But remember, the supercharger gear case is nothing special at all and only revs at 14k rpm max so the mentioned engine oil will work as well.
Old 07-22-2012, 08:33 AM
ccfulton's Avatar
Received 1,106 Likes on 763 Posts
Pontiac GTO = probably a Holden or Vauxhall for you
Pontiac G8 = Vauxhall VXR8
Cadillac CTS-V = Cadillac CTS-V
There is another thread about this topic: https://www.jaguarforums.com/forum/x...ectancy-53729/
Originally Posted by macbut999
I have listed a few possible oils below:
Air BP Turbo Oil 2380 (1 US Quart/0.946L)
Mobil Jet Oil 2 (1 US Quart/0.946L)
Aeroshell Turbine Oil 500 (1 US Quart/0.946L)
GM Part No 12345982 (4 oz Bottle)
Jaguar Part No JLM12290
Just incase anyone needs a new snout refill plug/washer.
Jaguar Part No JLM12291
There are aeroplanes on the other side of the pond, yes? The turbine oil is not much more expensive than the GM stuff is in the US.
Old 07-22-2012, 08:46 AM
Very helpful info, thanks. The cost of air freight from the US is usually more than the bits!
The only time it worked for Jag bits was a set of Bosch plugs which are outrageously expensive here.
I'll look into Vauxhalls.
I can't resist a true story when some American friends were over here.
This is the Limousin where the famous brown cows come from and also the Limousine which was a horse drawn carriage with a curtain between the driver + passengers so he couldn't see the goings-on.
The other common cattle are the white Charolais.
Leaning on a gate the wife, looking at a field of brown cows, says 'Gee aren't those Chevrolets?'
'No, actually they're Limousines'
Old 07-22-2012, 09:28 AM
Jochem00's Avatar
The chevrolets in europe are the former daewoo models. They merged so daewoo became chevrolet. Not sure if the V8 models are available through the same dealers, but Opel will give you a good chance allthough the dealers in France can be a pain if you need some help.
Old 07-22-2012, 05:30 PM
vettegood's Avatar
Please fill out the poll!
Happy Motoring...
  #28
Old 07-22-2012, 06:22 PM
Stumpy's Avatar
If you are after the complete kit look at Ebay item number 160676739255
I checked on the french version of the site and they are quoting 30.83 euro + 4.82 euro post.
steveinfrance (07-23-2012)
Old 07-23-2012, 11:10 AM
vettegood's Avatar
get your vote in.
  #30
Old 08-21-2012, 10:01 AM
azeteg's Avatar
Having no detailed prior service record on my car (only fully stamped regular service book), I decided to change the supercharger oil today, using the kit from XKZ Parts.
It was a bit tricky to get the plug out at first, space is very limited. But once the O-Ring is depressed, one can easily unscrew the plug with the fingers. I managed to get some 150-160ml of badly stinking coffee-colored substance out of the thing. One has to fiddle around a bit with the hose, to get it to pass properly into the sump. At first try, you'll only manage to stick it in about 1cm. Then fiddle around a bit, trying various angles and forces, and it will slip in another 3-4cm, enabling you to get all the oil out with the syringe. Then, using the syringe, just fill it up with the fresh oil, until the oil is level with the screw threads in the filler opening.
As someone mentioned, a rag under the plug is good to have when filling up. I also had the rag there during unscrewing the plug, in case I would slip and drop the allen key or the plug. It could easily get lost/stuck down there, it is a very tight space.
Will check the power and MPGs (Massive Power Grin's) later tonight. I doubt it would make much of a difference, since the old oil didn't look that bad. Only the smell was terrible, really.
ZJag
26
09-05-2016 03:33 PM
Dymaxxion
09-04-2015 02:40 PM
bdboyle
09-04-2015 06:16 AM
Jag-o-nomic
09-04-2015 03:07 AM
pnwrs2000
09-03-2015 11:55 AM
Quick Reply: supercharger oil change kit
