Suspension faulr warning
Old Sep 3, 2017 | 03:52 AM
Schnauzer's Avatar
Default Suspension faulr warning
my 1999 xkr is showing suspension fault warning. No fuses blowing and it drives fine, just annoying that every time you look at the speedo you have the warning script and light glaring at me.
Old Sep 3, 2017 | 12:20 PM
RDMinor's Avatar
Default Do you have the air suspension?
Is your car equipped with the active suspension? Also have you had time to get a scan done that would show what fault codes triggered that light? If it's the active suspension it can throw a code without having a blown fuse or having a readily apparent effect on the cars handling as there may be a problem that at the moment the cars is equipped to compensate but it's still an indication that something is going wrong and it won't fix itself.
It will only get worse and get possible a lot more expensive.
Give us some feedback.
Old Sep 3, 2017 | 07:32 PM
prettybluefin's Avatar
check your brake light switch...my coupe had that fault, and it was the switch...a $250 repair.
Old Sep 4, 2017 | 04:44 PM
lossking_'s Avatar
I've got it too, it's the ABS module
dchristy
Aug 22, 2022 11:29 AM
pk4144
Oct 30, 2016 10:00 PM
phanc60844
Oct 15, 2016 09:09 AM
JimC64
Detailing / Car care
Dec 2, 2010 11:52 AM
