Swap 98 XJ8 into 97 XK8?
Hi everyone,
There is 97 XK8 locally, looks very nice in the ad but says low compression in 2 cylinders. I have my 98 XJ8, which is getting tired, but the engine runs great.
If I am correct these are both AJ26 engines?
What is to stop me from doing a transplant?
Thanks in advance.
Thanks in advance.
Hmmmm, mighta answered my own question here. The XJ has VVT, as evidenced by an electrical connector on the forward face of the engine. From what I have heard, the 97 XK would have an AJ26 without VVT. Can anyone confirm?
Thanks.
Thanks.
The 99-02 XK8s (AJ27) have VVT (Variable).
All XKRs do not have VVT.
More ramblings. The 97 either has VVT or it doesn't. If yes, no problem. If no VVT, then I could remove the VVT from my 98, and it should not be an issue since the 97 ECU isn't looking for VVT.
I could see maybe reusing the 97 throttle body, don't know if they differ (my 98 has the problem where it quits on the highway sometimes).
What about the transmission? My 98 was rebuilt a while back and should be compatible, I would think. Could be a good project if the car is nice (haven't heard from the guy yet).
These can be told apart by having no VVT connectors, then ones on the front of the engine, then ones on top of the valve covers.
Luckily I am only talking normally aspirated here. The SCs complicate life even further!
mls0036
Oct 17, 2015 10:03 AM
