system check error
Old Jul 10, 2017 | 10:27 AM
reko19's Avatar
Default system check error
Hi everyone. Last weekend nearly got stuck twice. After starting a car (1997 XK8) I would get the following error messages during the system check: bonnet is open, boot is open, passenger door is open, driver door is open, (and I think check lamp came up as well). There was no way to place it in drive, stuck in park until the messages are cleared. What seemed to clear an issue is opening and closing the bonnet, although I opened and closed both doors, trunk, etc. Don't know if it matters, but the car was left in the sun for most of the day every time it happened (twice). Any ideas?
Thank you.
Old Jul 10, 2017 | 11:36 AM
avern1's Avatar
Sounds like you need a new battery. The Jag's don't like low batteries. A bad battery will start the car but not provide enough voltage for the modules. When the voltage drops during starting the modules throw up all kind of signals.
Old Jul 10, 2017 | 12:52 PM
RJ237's Avatar
If you don't drive the car often the battery could need charging. But as Vern says, it may be going bad. The parts stores will run a load test. It's a good idea to use a battery maintainer when the car is not being used. It can be connected to the bulkhead connectors under the bonnet.
Old Jul 10, 2017 | 02:54 PM
reko19's Avatar
Thanks guys. Was looking at some other posts, I think you are absolutely right. I am due for the battery replacement anyway so will proceed accordingly. Will report back if the issue persists.
Thank you for your help.
Old Jul 11, 2017 | 03:39 AM
Originally Posted by reko19
..... What seemed to clear an issue is opening and closing the bonnet, although I opened and closed both doors, trunk, etc. .....
After that routine I was going to suggest sacrificing a chicken and throwing a double six to start but a new battery is likely to be more effective.
A battery tender will effectively pay for itself in preventing this kind of trouble and extending battery life.
Old Jul 11, 2017 | 05:26 AM
Diddion's Avatar
.....I'll bear this in mind for my next Jaguar problem. In this instance I would consider a battery hen.
Old Jul 11, 2017 | 07:35 AM
Originally Posted by Diddion
.....In this instance I would consider a battery hen.
Old Jul 11, 2017 | 08:07 AM
reko19's Avatar
The battery I replaced has a Jaguar sticker on it. Is it possible that it is original 1997 battery??
Old Jul 11, 2017 | 08:51 AM
Don-T's Avatar
You might be able to get a manufacture date from the top sticker, some batteries have the date stamped into the + terminal.
Old Jul 11, 2017 | 10:51 AM
OE Jaguar batteries have the date of manufacture stamped into the top of the negative post:
This example shows 23-12 indicating manufactured in the 23rd week of 2012.
