T B removal question RESOLVED
Removed elect. plugs and breather tube and one coolant hose. The other coolant hose is very hard to get to. Is there a easy way like unbolting the T B first to access the hose better, or anything else to try? Also how is the cable detached? I'm sending T B in for rebuild......Many Thanks!
Mick,
There's been many posts on the TB but it sounds like you've got stuck and a suggestion to do a search may not be the most helpful with your TB half disconnected on a Friday night!
If you need the JTIS removal procedure, you can download it from my MediaFire account:
Free Cloud Storage - MediaFire
The cable, connectors and hoses can all be disconnected before removing the four TB bolts.
