Taking the car out of hibernation
Old Apr 13, 2020 | 12:53 PM
ozbot's Avatar
Default Taking the car out of hibernation
Morning Folks,
We've had 2 weeks of day time temperatures above freezing so I'm thinking / hoping I can get the car on the road by the end of the month.
Is there anything special I have to do before firing her up for the first time besides lowering the tire pressure and checking fluids? The car
has been on the battery tender all winter so the battery should be good and it got a rad flush and new -40 antifreeze and an oil change before
I parked it. I'd like to put her on the driveway this week so I have a little more room to work on it before the driving season.
Thanks in advance. Tom
Old Apr 13, 2020 | 03:28 PM
RJ237's Avatar
As long as the fuel pump hasn't failed you should not have any problems. Be sure to get it to operating temp. before shutting it off, not a good time to risk bore wash.
Old Apr 14, 2020 | 08:18 AM
Barry_Tucker's Avatar
My startup procedure after a long Nfld winter. I am not being "smart" or "sarcastic" ..this is what I do.
1/ Make sure there is oil and coolant. 2/ Turn key 3/ Let idle for a minute or so while looking and listening for anything odd. 4/Go for a short drive , usually to my local indy mechanic to make an appointment for an after winter oil change .
Since I have bought the car it has started witin 5 seconds ; after sitting idle 5 months or more.
Old Apr 14, 2020 | 10:14 AM
ozbot's Avatar
Hi guys, thanks for your replies. I think some times reading the problems people have
on the forum I get a little paranoid. After all it is just a car, a pretty one, but a car not a
piece of glass.
Old Apr 15, 2020 | 08:38 AM
CorStevens's Avatar
another technique for a car that sat for a while is to pull the fuel pump relay and crank the engine until oil pressure starts to show, light goes off or pressure needle moves. replace fuel pump relay and start. added benefit that the cylinders were warmed by the compression. if the car sat for a really long period of time, remove the spark plugs, add one squirt of motor oil to each cylinder and perform the no fuel crank with the plugs removed.
would add that it is a good idea to check the air box for tenants prior to cranking as well as the intake valley and general hiding spots for rodents. if you used poison baits and peppermint oil, this is not so much of an issue.
Old Apr 15, 2020 | 01:13 PM
ozbot's Avatar
Hi WhiteHat,
Thanks for the great advise. This is the first car I've bought with no block heater to
plug in during the winter. My trans am and mx6 I plug in and can just start up in the
spring with no issues. I'm hoping the xk8 will be the same. As far as critters go I put
out mouse traps and bounce dryer sheets changed monthly. I haven't found any yet,
dead or alive.
Old Apr 15, 2020 | 02:27 PM
CorStevens's Avatar
Originally Posted by ozbot
Hi WhiteHat,
dead or alive.
i believe that there is a block heater kit for these cars. it is probably more useful for when the vehicle is actually operated in the very cold weather, although it might prevent condensation in storage. just not sure if these are meant for constant use on a stored vehicle.
Old Apr 15, 2020 | 02:46 PM
ozbot's Avatar
Yes there is a block heater for the xk8 but I was told that it didn't need it if the car was being stored for the winter.
The other cars I plug in at the end of October until spring but they sit outside under tarps. I've never had an issue
with it but they probably don't need to be plugged in all winter.
Old Mar 29, 2026 | 12:21 PM
Oldguyskiing's Avatar
Default Hello from Fernie BC
Morning, I like the it, you have had a tougher winter then us.
Old Mar 29, 2026 | 07:37 PM
zray's Avatar
Default For hibernating cars:
Note:
Not just for these X-100 cars, but pertains to any car, vintage or otherwise; every engine has some degree of combustion blow by that by its acidic nature contaminates the oil.
it’s a gift to your bearings not to make them marinate in this acid bath all off-season. Depending on the severity of the blow by, the life of the bearings can be affected to a degree which shortens engine life.
it’s common practice to change the oil before the car goes into storage, not afterwards. This eliminates all ill effects that months of sitting in acidic oil can bring.
Z
Old Apr 2, 2026 | 05:08 AM
fabs0's Avatar
This can be done much easier:
Just floor the accelerator pedal while cranking. This will cut off fuel delivery.
After ~20 secs of cranking just release the pedal and start the car.
lsimon
Jun 13, 2020 05:00 PM
GhostRider9000
Apr 15, 2019 11:12 PM
10 XF Premium
Nov 21, 2017 08:34 PM
Big Wes
Nov 6, 2010 06:02 AM
mosesbotbol
Dec 9, 2009 09:01 PM
