tensioner knock?
Old Feb 23, 2015 | 05:21 PM
stevepaa's Avatar
Default tensioner knock?
So last year I replaced all chains and tensioners. I had a startup noise like a slap that goes away.
So several months later, I decided to pull it apart and look. One of the primary tensioners definitely has some play by hand maybe 1/16 inch at most while the other is fairly firm.
It is the left engine side that has the play.
Anyone else had this issue?
Old Feb 24, 2015 | 01:27 PM
stevepaa's Avatar
Default oops on chians and tensioners
when I did my chains and tensioners, I mistakenly mounted the backing plates behind the new tenisoners. Do not do that or you will push the curved ramp out and wear against the timing cover.
good video
Attached Thumbnails tensioner knock?-v-marks.jpg   tensioner knock?-cut.jpg   tensioner knock?-spaced-out.jpg
mikiep
Dec 20, 2019 07:37 PM
carl purchase
Oct 14, 2015 06:14 PM
LnrB
Oct 13, 2015 12:45 AM
millertic
Sep 30, 2015 08:11 PM
