Thermostat housing for 2003 XK8 4.2
Old May 2, 2025 | 08:02 AM
cjd777's Avatar
Thank you Oz, looks like the plastic fan blades, you avoided a big issue.
You are doing a lot of people a favor getting this straight.
Old May 2, 2025 | 12:59 PM
Jon89's Avatar
Watch those new URO hoses carefully for leaks. The two new URO hoses I installed on my former 2005 S-Type years ago leaked (more like a weep) from Day One. Even double-clamping them did not stop the slight weep....
Old May 2, 2025 | 01:15 PM
JACKP's Avatar
Glad to see you didn't have to lift the intake manifold. That could cause another can of worms.
Thanks for keeping us posted.
Jack
Old May 2, 2025 | 03:35 PM
fmertz's Avatar
Good call on replacing the valley hoses. From memory, there should be 2 of them.
Can't wait to hear about the fit of this great-looking part.
Best of luck, keep us posted.
Old May 2, 2025 | 05:36 PM
2003RagJag's Avatar
I used all new bolts ready available at Home Depot or Lowe's. I got mines at HD
Bleeder on top
Bleeder on top
Old May 2, 2025 | 05:45 PM
2003RagJag's Avatar
I bought the valley hoses, but those are for the next adventure. Replacing all the hoses under and behind the intake manifold and booster pump.
Old May 3, 2025 | 07:12 AM
Jon89's Avatar
Thanks for the great side-by-side comparison photos. If this 4.2 aluminum thermostat assembly indeed fits well and does not leak, my guess is that the ebay seller will sell a ton of them based upon your experience....
Old May 3, 2025 | 09:07 AM
  #28
2003RagJag's Avatar
A little more work before going to my grandson's birthday party.
Installed new tensioner, idler and belt.
Also got upper radiator hose in, but had two remove and cut 5mm of the radiator end so it would not touch the air box.
Hopefully by tomorrow late afternoon I'll be done.
Old May 3, 2025 | 11:22 AM
kstevusa's Avatar
Thanks for the info and great photos. Appears the quality and appearance are first class. Have a ride and congratulate yourself.
Old May 3, 2025 | 07:30 PM
  #30
RJ237's Avatar
Since the housings come from China, they probably will not be available soon.
Old May 3, 2025 | 09:59 PM
  #31
JACKP's Avatar
I just ordered one for my 2005 XK8 in case the tarrifs hit. Thanks for trying it out for us.
Jack
Old May 4, 2025 | 08:19 AM
  #32
JimmyL's Avatar
That thermostat housing is impressive. It looks like the front-side compliment to the octopus hose !
Old May 4, 2025 | 09:10 AM
  #33
2003RagJag's Avatar
You call it impressive I call it crazy engineering. On this engine it's all about the looks, minimizing all the visible hoses and wires. Who cares about the guy who has to work on it later...
4.2 Jaguar block
Old May 4, 2025 | 11:18 AM
  #34
Brian G's Avatar
Originally Posted by Ledmi
It appears that this is now "out of stock".
Old May 4, 2025 | 12:36 PM
  #35
JACKP's Avatar
Amazon might still have them.
Jack
Old May 4, 2025 | 12:53 PM
  #36
Brian G's Avatar
Jack
I cannot locate one, but I'm on the Canadian Amazon site. If someone can identiy a source for these, it would be appreciated.
Old May 4, 2025 | 05:14 PM
  #37
2003RagJag's Avatar
Got one problem, the connector for the coolant temperature is different. I filled down the out of place ridge and plugged it in. But the temperature gauge is not working. I'll have to try to remove the sensor without breaking the housing and hopefully the original fits in. Other than that everything looks fine so far.
Original
Original
This came with the aluminum housing
Had to file off, but I'm not getting a temp reading
Old May 4, 2025 | 05:17 PM
  #38
2003RagJag's Avatar
No leaks so far...
Old May 4, 2025 | 06:11 PM
  #39
JACKP's Avatar
Might have a better chance of getting the sensor out by loosening it while hot and aluminum expanded a bit. I would want the temp sensor working with a Chinese thermostat.
Jack
Old May 4, 2025 | 08:00 PM
  #40
2003RagJag's Avatar
Jack
I did and everything works now. With that if you have a good working sensor swap it before installing the thermostat housing. The one that comes with it has not only the wrong guide slots but it also does NOT work with our car.
