Third time not the charm.
The only way you will know for sure thats its not a power draw from something not shutting down etc is to put an ammeter in series with the battery and monitor it for a period of time as it sits.
When I bought my XK8 it had been sitting for at least a year or 2. The amp didn't go bad from sitting and it killed the battery in 2 days or less. I think the car was parked because of that problem and nobody took the time to troubleshoot it.
Dave
Dave
If I understand right, the idea is not that keeping power on will prevent this, but rather that if we ever remove power then the required re-boot might fail. Correct? But if this is so, then it seems we also would have to avoid a hard reset on such cars, or a battery swap w/o a temporary power source during the swap. Maybe I misunderstand the point.
ALL, great to get advise and different directions to go. Thanks to all.
I had the battery charged at Advance and they say the battery is fine. 12.58V after charge and two days later 12.50V, so they may be right.
One thing I see is the Beav opinion of the cables could be the resistance that is causing the small charger not to be effective and possibly a draw. I need to confirm this.
Been really busy over the last few days, so I just wanted to up date all and will get in garage shortly.
Wayne
Wayne
12.50 sounds good to me. Not like a new battery, but serviceable. At the rate you described it falling, I thought it would end up lower.
I won't pound the table on this further, but if any significant resistance has crept into the charging path it might effect how long it takes to charge the battery, but not the final charge achievable. Also, you'd have other symptoms.
When you re-install the battery, if it discharges quickly then I think Dave's idea is very likely the right one.
Hang in there; you'll get it.
We can bleed some surface charge to get an immediate reading (it's possible to do too much or too little), but the most accurate reading comes from letting the battery rest after charging. 4+ hours is good; 8 hours is plenty.
Why wait? A small discharge for a few seconds will do the job just fine.
Unless there's a wiring problem, the engine-compartment terminals, battery clamps, or the battery terminals themselves are all equivalent for charging. A digital voltmeter can be used to check this. Really. There probably won't be more than 1 or 2 one-hundredth of a volt difference, if it's even measurable.
In cars there's always a 'problem'. It's just whether or not the problem is big enough to be inconvenient. Multiple connections are the usual culprits. Every connector is a chance for a voltage drop, no matter how small.
If there is a source of significant resistance in the circuit when using a charger, it's in a place we never think about; those skinny wires with their weak clamps coming out of the charger itself.
You'd be surprised how much current those skinny wires can flow. While there is a limit, the real reason for wire/amp ratings are heat and insulation capability - read: fire safety. I've watched an instructor in a Ford classroom start a 2.3l engine with 14 gauge wires. Sure, they got hot but the engine started just fine.
Best bet? Put the charger back in the trunk where there wasn't a problem.
IBeav, Now that is what I'm talking about. I see the light and it looks like I had it figured out, but didn't know why. You my be BFF, LOL.
Thanks Beav, as this may or may not be the case but makes a lot of sense.
I will get the battery installed tomorrow and we shall watch it like a hawk.
Wayne
Wayne
Point of order, please. What is shown as a quote from me in the post #24 is not what I posted, but rather a mix of my post, and somebody else's (Beav's, I think) comments and disagreements. Post #18 is what I said. I think we're all entitled to have what we post quoted in tact, if it's to be identified as a quote. I'd appreciate if this could be sorted out. But it is what it is, I suppose.
It's hard enough being responsible for things that I actually did say.
But on to the subject at hand ...
- After charging, it's better to wait 4+ hours and read rest voltage than to get a reading after a quick bleed of surface charge. This is so because rest voltage gives a more accurate measure of the battery's state-of-charge. If we have time, let's do the best measurement possible. See for example batteryfaq.org, batteryuniversity.com.
-Where we connect the charger -- at the battery vs. the engine-compartment (front) terminals -- will not effect what's going on here for the reasons shown in post #18. Easy to verify with a DVM; there is zero resistance between front terminals and battery.
And yes, of course we have to remove the charger no matter where it's connected, while testing for parasitic voltage drop. As far as I know, nobody has suggested otherwise. Nothing to do with a full-time battery tender, so descriptions of a charger interfering with the parasitic test ... I can't follow.
Wolfy
May 28, 2024 08:06 AM
