Thoughts on oil weight/viscosity
Old Feb 25, 2018 | 01:45 PM
Barry_Tucker's Avatar
Default Thoughts on oil weight/viscosity
What are your opinions on using a slightly heavier oil in a higher mileage car ?
Mine has over 180,000 km on it but ,so far, does not burn or otherwise use up oil. It used to be common practice to use heavier oil in older cars to help keep oil pressure up etc. I was thinking of moving to 10w30 instead of 5w30
I am not concerned at all about a possible minor loss of fuel economy.
Last edited by GGG; Feb 26, 2018 at 08:57 AM. Reason: Correct 5w20 to 5w30 - see post #11
Old Feb 25, 2018 | 02:23 PM
StuG's Avatar
"Mine has over 180,000 km on it but ,so far, does not burn or otherwise use up oil".
My thoughts are, if it ain't broke, don't fix it!
Old Feb 25, 2018 | 03:09 PM
Mikey's Avatar
Here we go again .......................
Old Feb 25, 2018 | 03:28 PM
JagV8's Avatar
I'm a little surprised 5W20 is the right oil but if it meets the spec and the car is doing so well, why change.
Old Feb 25, 2018 | 03:37 PM
michaelh's Avatar
Barry,
If your motor isn't using oil and you have no other issues, then carry on doing what you're doing.
If you are concerned about the oil pressure, then you can hook up/tee off a 'real' oil pressure gauge, or - if you don't have NAV - then invest in WhiteXKR's 'RealGauge'
Just my
Chill, Mikey
Attached Thumbnails Thoughts on oil weight/viscosity-71uz6okvyil._sl1500_.jpg
Old Feb 25, 2018 | 04:49 PM
I have purchased a Real Gauge kit , just have not got round to installing it yet. My old Cooper S used 20w50 so 5w20 seems "mighty thin" Thanks for all the input. I expect I'll stick with the 5w20
Old Feb 25, 2018 | 11:15 PM
zray's Avatar
Mobil 1 0w-40 .... an excellent oil for high performance european vehicles, superb wear protection
https://mobiloil.com/~/media/amer/us...pecs-guide.pdf
Mine has over 180,000 km on it but ,so far, does not burn or otherwise use up oil. It used to be common practice to use heavier oil in older cars to help keep oil pressure up etc........"
your car has about 110,000 miles on it. That's not a high mileage car, it's barely broken in.
Z
Old Feb 26, 2018 | 12:53 AM
StuG's Avatar
Old Feb 26, 2018 | 02:54 AM
..... I was thinking of moving to 10w30 instead of 5w20 .....
What decided you against using the recommended 5W-30 oil specification up until now?
Thoughts on oil weight/viscosity-oil-specification.jpg
Other than Jaguar having a commercial arrangment with Castrol and therefore recommending their products, I can see no bias in the recommended oil specification or any reason to vary from it.
Old Feb 26, 2018 | 08:19 AM
zray's Avatar
Originally Posted by GGG
"......What decided you against using the recommended 5W-30 oil specification up until now? ...."
"........ than Jaguar having a commercial arrangment with Castrol and therefore recommending their products, I can see no bias in the recommended oil specification or any reason to vary from it.
actually, the 5w-30 is just the recommendation for best fuel economy, as the manual states. But in climates of higher temperatures, or when the car is being exercised more aggressively, then 0w-40 or 5w-40 are also recommended, hence my preference for the Mobil 1 0w-40
but as everyone has already noted, these best oils threads are mainly redundant. However, they do serve to illustrate the numerous oils that can be used successfully.
And it bears pointing out that having ones preferred oil analyzed during the oil change is the best way to determine how effective it still might be, and which parts of the additive package have been used up.
Z.
Old Feb 26, 2018 | 08:27 AM
My mistake ....I read 5w20 instead of 5w30 DOH
Old Feb 26, 2018 | 09:00 AM
I've edited your original post.
Many members read the first post in a thread and ignore all the rest before replying.
Old Feb 26, 2018 | 01:17 PM
Mikey's Avatar
The OP lives in Newfoundland.
Old Feb 26, 2018 | 01:41 PM
zray's Avatar
I sure wouldn't want a 5w- anything then. 0w-30 for sure, unless he's really putting the car to the test
Z
Old Feb 26, 2018 | 01:50 PM
Mikey's Avatar
You either don't understand oil ratings or the Newfoundland climate, or both.
10W40 is not on the list at all, nor is the mandatory use of synthetic. Factory fill and dealers used dino oil for N. Am delivered cars
Old Feb 26, 2018 | 02:06 PM
zray's Avatar
i wouldn't jump to any hasty conclusions about my engineering or geographical knowledge. Or hands on experience for that matter. I've been building engines for 50+ years. I haven't been asleep the whole time.
Just my opinion, but anyone using a non synthetic today, even in a lawn mower, just doesn't care much about engine longevity.
Z
PS who's talking about 10w-40 ? did I miss that ? I did have a typo 4 posts back, ( wrote 10w-30 but meant 5w-30) but corrected, post haste, and noted correction .
I mentioned 0w-40, because that's what I use, and it's listed in my manual as appropriate for my climate
Old Feb 26, 2018 | 02:52 PM
giandanielxk8's Avatar
What viscosity is best for a tropical climate?
Old Feb 26, 2018 | 05:14 PM
Good question ...... because this thread is heating up.
Old Feb 26, 2018 | 05:35 PM
zray's Avatar
ha ha. A good one.
according to my 2002 Vehicle Care manual section 3-7, if the lows are in the 50 (F) range and the highs are in the 100's (F) or higher, then recommended oils are the 0w-40 on the low end of that range and a 5w-40 for the upper range.
again, those are the manuals recommendations, so don't hate me or question my geography skills.
Z
Old Feb 26, 2018 | 05:50 PM
Mikey's Avatar
Z
My tired old eyes saw Mobil 10w40 in your posts and not Mobil 1 10w40. Apologies offered.
