Throttle body coolant hose 2000 xk8
Old Mar 6, 2016 | 08:17 AM
dennysjag's Avatar
Default Throttle body coolant hose 2000 xk8
In the last week I have replaced the valley hoses and the dreaded octopus hose. I found a very dry rotted c shaped hose that attaches to the throttle body and i think the other end attaches to the tube from the valley hose. Its not a big hose but I cant seem to find a part that looks like it in my searches.
Thanks in advance
Old Mar 6, 2016 | 09:14 AM
NBCat's Avatar
Perhaps you can post a photo of the hose. There is a hose that matches your description: NNE3246BA that is part of the fuel injection system.
Old Mar 6, 2016 | 10:35 AM
dennysjag's Avatar
NBcat
I think you have solved the riddle. The hose is shorter on one side than the pictures but I believe that the PO shortened it since there are 2 spring clamps pushed towards the center and two screw camps are at the connections. Thanks for your help
Old Mar 6, 2016 | 01:02 PM
stevepaa's Avatar
you should find two hoses to throttle body.
File Type: xls
Old Mar 6, 2016 | 01:12 PM
dennysjag's Avatar
Thanks. Only one appears to be rotten. Maybe I will just get both and be done with it.
Old Mar 6, 2016 | 06:54 PM
brgjag's Avatar
do it all while you are in there. Ya only want to do it once. I was in your place about this time last year
Old Mar 6, 2016 | 08:04 PM
dennysjag's Avatar
I will order it tomorrow. Then start pecking away at suspension, lower ball joints
rickpwilson
Aug 20, 2020 10:08 AM
Spurlee
Feb 25, 2016 11:35 AM
hawaiianjag
Feb 22, 2016 05:49 PM
Travis O'Gallagher
Feb 22, 2016 05:47 PM
michaelodonnell123
Feb 9, 2016 10:11 AM
