Throttle pedal position sensor plug, HELP
This is my 3rd xk8 and they all have had the same problem. I can’t imagine that every xk8 out there x doesn’t have the same issue.
the electrical wire loom plus onto the throttle body . Driver side on US model. The throttle pedal position sensor female plug from wire harnes to throttle body crumbles to pieces when you just basically touch it. The car won’t run without it. The TPS on passenger side is different.
Has or does anyone have a replacement source? Seems to be a huge issue.
any help appreciated. Thanks in advance , scott
If you mean the PPS plug, it might be this one?
https://www.bmotorsports.com/shop/pr...kknUAto8dCV1nc
Whereas I think the TPS is Tyco/TE econoseal 3, with the small slots on either side and the bottom...
Erndiego619
Apr 5, 2012 11:05 PM
