timing chain tensioner change
Old Aug 25, 2021 | 07:16 PM
fourkegdave's Avatar
Default timing chain tensioner change
Hello all,
I have just changed my tensioners to the updated metal ones and used a kit with the metal backed chaln guides.....I have noticed that the timing chains are rather tight at this point....I can barely get 1/2" of the wedge under the tensioner and blade to lock the cam sprockets in place.....in fact when I put tension on the exhaust cam gear to take up the slack in the system the main chain didn't move...it was already tight. Is this of some concern? I have rotated the engine by hand and everything moves and nothing is hitting, so its timed correctly. I did notice that the blades I used from the kit are twice the thickness of the original OEM ones.....of which I have a set....not sure if its ok to carry on. Any insight will be greatly appreciated.
2000 XKR
thanks,
Dave
Old Aug 26, 2021 | 11:48 AM
NorXKR's Avatar
I did mine a couple of months ago, and had the same experience. So far so good.
Old Aug 26, 2021 | 12:56 PM
Good to hear. Im just worried of the guides getting worn real fast
Old Aug 26, 2021 | 05:24 PM
Nickel's Avatar
Same here again. Nice and quiet though.
Old Aug 26, 2021 | 09:33 PM
xalty's Avatar
it was your choice to use the wrong guides
for $70 all in i would too
VivaJag
Feb 12, 2020 04:34 AM
mel
Apr 8, 2018 03:37 PM
Rae
May 27, 2012 08:54 PM
coolhandluke
May 26, 2012 09:18 PM
linconlsv8
28
Feb 20, 2012 12:37 PM
