Tip for safe jumpstart. Post-winter dead XKR RESOLVED
Old Apr 19, 2014 | 12:54 PM
david i's Avatar
Windows reprogrammed. Thanks again
-d
Old Apr 20, 2014 | 06:24 AM
East Haddam's Avatar
Originally Posted by Paul Pavlik
Charging Points Under Hood (Under Bonnet):
There is an identical looking terminal with a tethered protective cap on the right side of the car (under the plastic cover near the windshield if memory serves me correctly). Is it a twin to the charging point on the left side and if it's not - what's it used for?
RB
Old Apr 20, 2014 | 07:58 AM
auburn2's Avatar
Originally Posted by Dennis07
I wish Jaguar had added one item to their instructions above. Before removing the jumper cables, it's best to shut off the car that was jumped (the other car should have been turned off through the whole operation). If the jumped car can't then be restarted without the jumper car connected, then of course you have to abandon this, but it's best to disconnect jumpers with both cars turned off if possible.
Why does the other car needs to be off? If it has a good working voltage regulator on the alternator how it will harm the electronics to have it running?
I found this description odd since every time I have jump started a car I've had the good car turned on.
Old Apr 20, 2014 | 09:24 AM
Paul Pavlik's Avatar
RB
The right side terminal connects directly to the Starter and also connects to the Battery through 2 250 amp fuses in parallel.
It could also be used to charge the Battery, but is not as easily accessed as the terminals shown on the pic.
The terminals on the pic connect to the Driver and Passenger Fuse Boxes and to the Battery through a single 250 amp fuse.
Old Apr 20, 2014 | 09:50 AM
Dennis07's Avatar
The part about the booster car being turned off during the jump comes from the Jaguar proceduure itself (post #3 above). I do think this is best practice, since otherwise when the jumped car starts we have two charging systems "talking to each other".
What I wish had been added is to have both cars turned off before removing jumpers. Those sparks we sometimes see when doing this are indicative of big voltage spikes.
We could ignore all this stuff and get away with it 99 times out of 100. But I think it's worth taking every possible precaution, as that 1% can get seriously expensive with our cars.
Old Feb 20, 2021 | 04:30 PM
Brannon Richards's Avatar
Default Opening the XKR trunk
Originally Posted by GGG
Ask anyone who has a flat battery and a seized luggage compartment lock which can't be opened with the key!
You can apply enough juice to pop the luggage compartment lid from the dash button and get to the battery.
The trunk can be opened when dead. There is an unseen keyhole that many overlook or actually never see at all. On the trunk or boot door there is a XKR emblem. Looking at a glance it doesn't seem to be anything more than an emblem sitting the model but look closely. There is a hole in between the letters and/or numbers. Slide your key in and turn to pop the not open. Not sure if this applies to your year but it's a little secret. There are so many secrets hiding in these cars. It's pretty awesome. Anyone found their Jaguar pen in pen yet. You will....oh, you will.
Old Feb 20, 2021 | 05:44 PM
Originally Posted by Brannon Richards
The trunk can be opened when dead. ......
Welcome to the forums Brannon,
Many secrets have been revealed on the forums in the seven years since this thread was written.
Old Feb 21, 2021 | 09:46 AM
  #28
zray's Avatar
Sparks! The last connection you make will tend to spark both when making and breaking the connection. Sparks + hydrogen (from charging battery) = excitement!
It is very easy to avoid ALL sparks when attaching a battery charger.
Simply plug in your battery charger AFTER you have the charging leads in place.
No power to charger leads = no spark
Years ago an old power company lineman told me the secret of safely working around high (or any) voltage, “.......just make your plug into the power source your very LAST connection.....”
That keeps your exposure to voltage at the bare minimum.
Z
XJ8Johnny
XE ( X760 )
Feb 25, 2021 06:18 PM
Anthony8858
Nov 1, 2016 05:05 PM
magnum454
Feb 26, 2016 03:29 AM
Colorado Belle
Jun 25, 2014 06:32 PM
K.Westra
Jan 15, 2011 09:42 AM
