titanium bolt breakage - bbs detroit wheel
Old Jan 22, 2026 | 05:57 AM
pcock111's Avatar
Default titanium bolt breakage - bbs detroit wheel
One of the bolts has broken while splitting rims. Used oven soak at 200 degrees c. Going to try drilling and stud extractor. Any advice on method and sourcing replacement in UK. If all fails, will risk running without one but unfortunately it’s next to the valve.
Old Jan 22, 2026 | 08:09 AM
baxtor's Avatar
There is no particular importance to being next to the valve, only the valve bolt itself penetrates the barrel of the wheel.
Old Jan 22, 2026 | 07:18 PM
zray's Avatar
A competent machine shop can remove the broken piece without damaging anything
i would have that done before opting to run without the bolt
Z
Old Jan 23, 2026 | 02:04 AM
brinny's Avatar
Replacement bolts on ebay. Agree with zray, do job right.
Old Jan 23, 2026 | 05:46 AM
pcock111's Avatar
Thanks all.
Old Jan 23, 2026 | 03:04 PM
jhuertas's Avatar
You can do it. A workshop is best, but not just any workshop. I don't have those wheels. But to drill titanium, you need a tungsten carbide drill bit. To prevent slipping and avoid damaging the rim, I would use a drill press (or at least a system that allows you to lock the vertical movement with the rim securely held). To drill titanium, you have to use cutting fluid, otherwise the drill bit can be destroyed. Once the hole is drilled, use a screw extractor; if there's no deformation, it will come out fine. There's probably a workshop nearby that specializes in rim repair; my advice is to go there.
Old Jan 24, 2026 | 01:24 AM
pcock111's Avatar
much appreciated
JagX02
May 1, 2013 04:09 PM
wcnesta
Jun 14, 2012 10:19 PM
Chromey35
May 9, 2012 02:17 AM
JLperdue
Jul 24, 2011 11:22 PM
mphy98
Nov 23, 2010 12:43 AM
