Too much oil at top up - is this a problem
Old Apr 6, 2015 | 06:38 AM
worrasf's Avatar
Default Too much oil at top up - is this a problem
I have put a tad too much oil in at the latest oil/filter change
Level is above the Max hole on the dipstick (at the "A" of MAX) so probably about 300 ml too much. Is this likelyto cause any problems? I really dont want to have to go and drain some off if not as it's a real PITA at the moment.
Steve
Old Apr 6, 2015 | 07:11 AM
test point's Avatar
Shouldn't be a problem for a third of a L.
Old Apr 6, 2015 | 07:13 AM
Jon89's Avatar
Agreed. You'll be fine....
Old Apr 6, 2015 | 08:00 AM
worrasf's Avatar
Thanks for the reassurance chaps - weight off my mind - I'd read all sorts of horrors about foaming oil from crankshaft splashing/flinging - but then I read a thread saying some overfill by 1L if "racing" to prevent oil pump starvation under acceleration or around curves.
As a matter of interest with these engines how much is too much?
Happy Easter
Old Apr 6, 2015 | 11:30 AM
Jon89's Avatar
Depends on the engine. My wife's 2006 XK8 has the 4.2 engine and specifies 8.2 quarts. I just stick with 8 even. That engine is probably just fine plus or minus a quart. I believe your 4.0 engine requires less oil so the plus or minus margin may be somewhat less....
Old Apr 6, 2015 | 12:08 PM
worrasf's Avatar
Thanks - Jag specify 7.5 litres (8 US quarts) for my 4.0 engine.
Old Apr 7, 2015 | 12:39 PM
worrasf's Avatar
My OCD got the better of me so I pumped the XS out this afternoon - I forgot I had a hand pump used for emptying the sump on my canal boat engine - needed a bit of fine bore oxygen tubing from work to go down the dipstick holder and now I'm happy as the level is spot on the Max mark
Old Apr 7, 2015 | 12:48 PM
Lol, I have the other kind of issue of underfilling and make sure I do.
The diesel engine has a nasty habit of dumping fuel into the oil if it doesn't complete regen cycles. To combat this it involved regular oil changes, perhaps 3-4 per year and I ALWAYS only fill to just above the minimum.
toronadomike
Jan 22, 2026 10:13 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
alpecsa
Sep 7, 2015 11:55 AM
Will P
Aug 27, 2015 06:52 PM
