Top latch cylinder seals....?
Old Jun 20, 2016 | 04:54 PM
XJsc-guy's Avatar
Default Top latch cylinder seals....?
Just thought I'd ping here to see if there's any info floating around on this. My 98 XK8 has a very slow acting latch cylinder while the lift and lower cylinders work perfectly with no problems. The fluid was changed over to green a while back but I am suspicious that the latch cylinder itself still has some gooey yellow junk in there.
I have a spare latch cylinder from a 97 parts car that's clean but before used should probably be resealed. I checked around on having it done but the couple of places that do it are a little cagey about what they use for the rebuild and how long it will last (one of them even maintains they modify the cylinder to take their "better" seals). The warranty on the rebuilds is only 3 years which to me for an "improved" seal doesn't really seem like that long,..
I've looked inside the cylinder and it's pretty simple in there.
Has anyone on the list here done this before??? And know where to get parts- the seals?
XJSC-guy
Old Jun 20, 2016 | 06:49 PM
RJ237's Avatar
Send it to Top Hydraulics, they are the best.
Top Hydraulics | Rebuilt and Upgraded Convertible Top Cylinders, Pumps, Hydraulic Lines - Top Hydraulics, Inc
Old Jun 20, 2016 | 07:11 PM
gwagner's Avatar
2nd on Top Hydraulics. Quick turn around, great communications. Had mine done there about a month ago
Old Jun 20, 2016 | 08:32 PM
Jandreu's Avatar
3rd on Top Hyd. They did mine, next day turn around.
Old Jun 20, 2016 | 10:15 PM
XJsc-guy's Avatar
Default Thanks
Thanks for that- already talked to them as well as the place in Florida (the one that needed to modify the unit for their "special" seals...)
We'll if there is any other info floating around out there.....
Old Jun 21, 2016 | 06:01 AM
reb1999's Avatar
Default Top Hydraulics= agree!
Their best is the complete package, upgrade and overhaul both rear rams, front latch along with the complete Kevlar hose kit. Rich
Originally Posted by RJ237
Scottsgreenjag
Apr 14, 2016 11:14 AM
XKR8
Apr 12, 2016 07:17 PM
Navyflyer
Apr 5, 2016 05:25 PM
jamesackerman
Apr 4, 2016 03:47 PM
ETexJag
Apr 4, 2016 02:39 PM
