tough head bolts
Old Sep 13, 2023 | 11:55 AM
aced704's Avatar
Default tough head bolts
Hello, the group -
I am in the reassembly phase of replacing head gaskets (and many other things, including timing chain tensioners) on my 2000 XK8 (n/a) and have found tightening the head bolts to spec an incredible challenge. I've been using the workshop manual process (one round to 16 ft-lbs, one round to 26 ft lbs, one round of 90 degree turn, a second round of 90 degree turn). Using the T60 Torx bolts specified by Jaguar, and having great difficulty keeping the T60 bit in the bolt head even on the first round of 90 degree turn, getting concerned that the bolt head might cam out. Anyone else had this problem?
Old Sep 13, 2023 | 02:25 PM
xalty's Avatar
they’re not t60s they’re polydrive, tp60 works better if you want to use the wrong tool.
i use the hex head fel pros
Old Sep 13, 2023 | 02:46 PM
aced704's Avatar
Thanks, Xalty. Live and learn, glad I checked on this and grateful for your help. I'll order the TP60 bit before I do any damage.
Old Sep 13, 2023 | 02:53 PM
xalty's Avatar
look up ribe head bolt socket 12mm
Old Sep 13, 2023 | 03:02 PM
aced704's Avatar
Found this Ko-ken tool - sound correct?
Koken 4027.60-M12 | 1/2" Sq. Drive, Bit Socket for Ribe Screws
Old Sep 13, 2023 | 03:25 PM
xalty's Avatar
koken is good japanese stuff real expensive tho
CTA has a cheap one. i think i broke it once but that’s because we do a lot of work on 3l and 5ls
Old Sep 28, 2023 | 08:06 AM
aced704's Avatar
As it turned out, the head bolts I have are in fact T60 Torx, and after numerous unsuccessful attempts to use them I ordered the FelPro hex head bolts from Advance Auto. They went in fine with the same deep 1/2" socket I used to extract the old ones. These things take an alarming amount of torque.
Low-Tech
Mar 5, 2021 03:51 AM
Thang Nguyen
Jan 8, 2018 04:51 AM
jagdohrman
Jul 9, 2017 04:26 PM
BW_Hunter
Jan 26, 2014 09:35 AM
Shelby676
XJ40 ( XJ81 )
Jan 31, 2011 09:25 PM
