trans wire harness
Old Dec 2, 2024 | 07:08 PM
painterman98's Avatar
Default trans wire harness
I recently bought a 2001 xk8. I knew it needed some work. i`m trying to replace the internal trans wire harness. how do I remove the round connector that goes thru the rear case
Old Dec 3, 2024 | 06:26 AM
RJ237's Avatar
I think you have to rotate it to unlock. You should be able to get the info with a search.
Old Dec 7, 2024 | 02:11 AM
Y2KJag's Avatar
Sorry, late to the party. The part that fits into the trans housing just pushes in. It's essentially held in place by two fat o-rings.
Old Dec 7, 2024 | 08:18 AM
motorcarman's Avatar
AND a large 'U' clip on the outside.
Old Dec 7, 2024 | 12:16 PM
I got the clip off this morning. still can`t get it apart
Old Dec 7, 2024 | 12:50 PM
PUSH THE CONNECTOR INTO THE GEARBOX.
It comes out with the internal harness.
Old Dec 7, 2024 | 01:51 PM
I got the old one out and the new one pushed thru. now I need to get the external connected to the internal. it`s very hard to get at . I need to be able to lock it on and then put the clip on. tried to remove the trans mount for some room but I can`t get it off
Old Dec 7, 2024 | 07:03 PM
Put the 'U' clip on and THEN connect the harness plug so you don't push the socket back into the gearbox.
03Xtype
Jul 23, 2015 01:44 PM
Terry
Jul 28, 2014 07:03 PM
Leonard_85
Jun 6, 2012 05:36 AM
70gsrick
Jan 31, 2011 08:49 PM
FLLW owner
May 6, 2008 07:19 PM
