Transmission Fill-Hole Question
Old Nov 1, 2010 | 02:00 PM
Reverend Sam's Avatar
Default Transmission Fill-Hole Question
WHERE IS IT??? I looked at the JTIS, which has illustrations drawn by 3rd graders. It was no help. I can see that it's supposed to be on one side of the transmission or the other, but I just can't find it. The exhaust pipes seem to be in the way. Do you have to remove the exhaust pipes to get to it? I can barely squeeze my hand past them, and there's no way I could manipulate a tool or direct a hose into the fill hole with the pipes in the way. Maybe I'm just looking in the wrong place.
Old Nov 1, 2010 | 03:10 PM
WhiteXKR's Avatar
Sam, see the illustration on page 5 of this link: http://www.zf.com/na/content/media/u...28_Catalog.pdf
It is on the right hand side, near the rear of the transmission , just above the oil pan. If the exhaust is in the way, you will not be able to see it dead on. The short end of an 8mm allen wrench will probably need to be ground down to fit in the space between the exhaust and the fill bolt.
Old Nov 2, 2010 | 09:46 AM
Spurlee's Avatar
Great document. Do you have one for the ZF 5HP24 transmission?
Old Nov 2, 2010 | 10:55 AM
WhiteXKR's Avatar
This looks like it:
http://www.tema.com.mx/Manuales_files/5HP24.pdf
Old Nov 2, 2010 | 12:18 PM
70gsrick's Avatar
BTW this setup works perfect on my 99 XJ8 so not sure if it will on the XK as well. The 5/16 allen head and swivel together is the perfect length. Someone had rounded out the hole on mine and the 8mm was a little too small. The 5/16 seats all the way to the back of the hole in the plug.
Old Nov 2, 2010 | 01:11 PM
I'm drooling over your tool box.
Old Nov 2, 2010 | 08:29 PM
70gsrick's Avatar
Since I was under the Jag today I thought I'd snap a couple of pics of the plug for you.
Attached Thumbnails Transmission Fill-Hole Question-img_1332.jpg   Transmission Fill-Hole Question-img_1333.jpg
Old Nov 2, 2010 | 09:52 PM
Hang on a sec... you have a LIFT???
Can I come live with you?
Old Nov 2, 2010 | 10:19 PM
WhiteXKR's Avatar
Get your own home lift Sam !!
http://www.maxjaxusa.com/
(my apologies to your wife)
Old Nov 2, 2010 | 10:58 PM
70gsrick's Avatar
Ha..no lift, just really tall Jack stands!
aholbro1
Dec 29, 2024 06:46 PM
tomsjag
Jun 10, 2023 10:02 AM
Jandreu
Jun 30, 2022 03:10 PM
ahunt4
Sep 14, 2015 08:17 PM
AtholC
Sep 9, 2015 09:07 PM
