Transmission oil change just done
Old Aug 6, 2012 | 05:11 AM
steveinfrance's Avatar
Default Transmission oil change just done
Changed the oil at 85K miles.
A couple of points that may help.
The pan bolts were the small size Torx.
15 of the b*gg*rs would not turn at the sort of torque that really risked stripping the Torx.
However a small cold chisel and a tap with a lump hammer started them all easily - so don't risk it - if they don't undo easily use the 'American Screwdriver'
Second I used a temperature sensitive sticker on the pan 25° - 42° range.
It cost €1.50 and gave a good clear indication as the temp rose.
I've still got 9 of these left if anyone wants them.
Finally the oil that came out looked much the same as the oil that went back but I've lost the 3rd gear bark and the changes seem slicker
Old Aug 6, 2012 | 05:25 AM
Hey Steve, nice one and some good points thanks for sharing.
Barking and cats don't go together so glad you got that all sorted
Old Aug 6, 2012 | 07:12 AM
joycesjag's Avatar
Is that with Vodka?
Old Aug 6, 2012 | 07:17 AM
Originally Posted by joycesjag
Is that with Vodka?
Always!
I got the phrase from my father who was an engineer at Rolls Royce Aero engines.
The tool has served me well over the years!
Old Aug 6, 2012 | 07:28 AM
Steve,
Noting only one use of the personal pronoun in your post in regard to the application of the temperature sensitive sticker, I'm forced to inquire whether you actually did this change yourself or stood to one side in admiration as the local artisan performed his latest miracle?
Old Aug 6, 2012 | 07:39 AM
Graham,
It was a joint effort - he let me use the lift and I was going to do it all but he couldn't keep his hands of the Jagwar so a joint effort.
Having a Jagwar makes me a great expert on sporty motors of course so I had to spend an hour sorting out overheating problems in his rally car.
Old Aug 6, 2012 | 07:48 AM
Jon89's Avatar
Did you stick with Lifeguard 6, or go with another ATF?
Did you remove the old electrical sleeve and install a new one?
Old Aug 6, 2012 | 08:01 AM
I got a kit from this chap
XK8 and XKR Parts - AUTOMATIC GEARBOX SERVICE KITS for ZF5HP24, Mercedes 722-600, ZF6hp26 | Jaguar XK8 and XKR Parts and Accessories
which uses Shell ATF M-1375.4
I bought a sleeve from him but when I came to look it had already been changed.
Old Aug 6, 2012 | 08:55 AM
joycesjag's Avatar
Steve how do you know that the sleeve had been replaced already?
Old Aug 6, 2012 | 09:11 AM
Rick
I wish you hadn't asked !
It looked new and all around it was very clean while the rest was pretty grimy so err umm we sort of assumed it had been done.
Well it had hadn't it?
Old Aug 6, 2012 | 09:38 AM
Well you have a new one handy if it starts to leak so that's a plus. ;-)
Old Aug 6, 2012 | 09:47 AM
I don't want to ask but will I need to drop the pan again to change it??
Old Aug 6, 2012 | 09:49 AM
joycesjag's Avatar
Heres the answer YOU don't want to hear.
Yes!
Old Aug 6, 2012 | 09:53 AM
And was it a 2 minute job I should have done anyway ?
Go on, unmake my day, I was feeling quite pleased with myself.
Old Aug 6, 2012 | 09:59 AM
Don't worry Steve, It'll be fine.
Old Aug 6, 2012 | 10:07 AM
That's more like it. I'll try pressing the Thanks button repeatedly.
Old Aug 6, 2012 | 10:47 AM
wcnesta's Avatar
Steve
Thanks for the info. My Jag dealer found, on my last visit, that I had a very slight leak around the tranny, and I assume it was the sleeve. I plan to have the tranny oil changed next spring by my indy garage. The info about using the temp sensitive tape and the tranny kit info was nice to know. One of my Jag club members, also named Steve, changed his a couple of weeks ago without any problems. He has a lift in his garage, so It went well for him. Watching Rev Sam's video doing this job without a lift, is a job I would not want to attempt.
Bill N
03 XKR
Old Aug 6, 2012 | 11:06 AM
Bill,
+1 on that.
At well over 65 I wasn't going to grovel around underneath.
The penalties for shearing off a bolt are awful and this way we could really get a grip on things.
It took 1 hour and 5.5 Litres of fluid.
The amount dribbling out really reduced once the box got to 35°C - I reckon there's a bit of hype about the precise temp but the tape was brilliant.
Old Aug 6, 2012 | 11:38 AM
batroute's Avatar
[QUOTE=steveinfrance;558307] tap with a lump hammer started them all easily - so don't risk it - if they don't undo easily use the 'American Screwdriver'
In the Midlands we always used to refer to it as "The Brumagem Screwdriver"
Whatever it's called it never fails.
Old Aug 6, 2012 | 01:50 PM
wcnesta's Avatar
Bill,
+1 on that.
Steve
In our younger days, I am sure we would have done this. I am in my 70's now and am starting to slow down JUST a little.
Bill N
