Transmission pan replacement pan bolt size?
Old Nov 5, 2021 | 12:45 PM
babycar's Avatar
Default Transmission pan replacement pan bolt size?
I'm changing my traini filter and fluid in my 2002 XK8. I want to change the T-27 torx bolts to hex head (or anything other than torx), Would someone kindly tell me the size/dimensions of the bolts I need to buy ?Thanks.
Old Nov 5, 2021 | 12:53 PM
Jon89's Avatar
If you upgrade to the much-improved T-40 Torx bolts, you will be fine....
Old Nov 5, 2021 | 04:20 PM
xalty's Avatar
M6x22 or M6x23 depending on who you ask
https://www.fcpeuro.com/products/bmw...jnEEALw_wcB#qa
Old Nov 5, 2021 | 09:00 PM
motorcarman's Avatar
You are referencing the 6HP26 gearbox but we don't know if he is discussing the 5HP24?
Old Nov 6, 2021 | 06:50 AM
Jon89's Avatar
Are the ZF 5HP24 and ZF 6HP26 factory bolts different in length, thickness, or thread?
Old Nov 6, 2021 | 12:50 PM
xalty's Avatar
5hp = m6x23
6hp plastic = m6x29
6hp metal and ford 6r = m6x20
new genuine 5hp t40 bolts are $6.30 each, no go
mott
Aug 21, 2021 09:32 AM
Barry_Tucker
Nov 10, 2017 07:26 PM
Donna
17
May 20, 2014 09:43 AM
wordman
Feb 5, 2013 07:23 AM
yeeran
Jul 10, 2011 12:37 PM
