Transmission seal leaking question?
Old Aug 8, 2014 | 09:03 AM
The_Ikon's Avatar
Default Transmission seal leaking question?
There's a an 06 XKR for sale with a leak at the "transmission out seal" is this the same as the rear main seal or not? Also is this a diy job.. what is a fair quote to get it done?
Ikon
Old Aug 8, 2014 | 11:14 AM
The Coupe's Avatar
They're probably referring to a leak at the rear seal of the transmission, where it meets the driveshaft.
Old Aug 8, 2014 | 12:47 PM
Jon89's Avatar
It could also be a leak from the ZF electrical connector sleeve (a common issue with these cars). The replacement sleeves sold today have been redesigned and we hope they are not prone to leaking as the factory sleeves are. I don't believe that anyone who has changed this sleeve has reported that the improved version leaked as well. It's an inexpensive part, less than $20, but you must drop the ZF pan in order to change it (which means an ATF drain-and-fill along with the sleeve change)....
I would find out exactly where this leak is before pursuing the car....
Old Aug 8, 2014 | 01:38 PM
Rezzz's Avatar
Any chance you have a part number for that animal?
Old Aug 8, 2014 | 01:47 PM
C2C 39599 I think for the ZF boxes only.
Old Aug 8, 2014 | 02:19 PM
Rezzz's Avatar
I'm thinking that might be part number JLM21109 for us earlier XK8 guys. They didnt replace this when I had my transmission rebuilt recently so I think I best do so before I drop the trany back in assuming the older XK8s had the same issues?
Old Aug 11, 2014 | 06:42 AM
The_Ikon's Avatar
Thanks for the reply guys but the owner has not clarified the leaking issue. He's to send diagnosis of issue. Thanks guys I'm just trying to arm myself with knowledge, costs and potential bargaining tools.
XJsc-guy
Sep 25, 2015 11:09 AM
sogood
Sep 15, 2015 07:35 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
d a
Sep 3, 2015 02:34 AM
OkieTim
Sep 2, 2015 12:48 PM
