Transmission slip
Old Mar 22, 2012 | 05:37 AM
trogers's Avatar
Default Transmission slip
I have an 03 XK8.. the car runs great...except I note a steep inclined hill on my way home from work..when I take that route..as I am going up the hill, the transmission makes an odd noise and the car slows as though it doesn't want to stay in gear... this is in the Automatic positioin..when I put it in 2 then it seems fine.....I had the Jag dealer check the transmission and he says its fine..just added a little fluid....any thoughts?
Ted in Chanhassen, Mn
Old Mar 22, 2012 | 09:37 AM
oldmots's Avatar
It has all the symptoms of low fluid, so keep an eye on it and check for leaks.
Old Mar 22, 2012 | 09:42 AM
oldmots's Avatar
Should have mentioned, if anyone has had the filter out, pull it and see if they got the o-ring back onto the filter feed tube correctly. If it is not in there, when fluid flows away from the bottom of the valve body, the tranny sucks air.
Old Mar 23, 2012 | 05:30 AM
trogers's Avatar
thanks gents.... this is helpful...i'll get it checked out....
Poet
Feb 7, 2025 02:18 PM
aholbro1
Dec 29, 2024 06:46 PM
ryan_border
Dec 23, 2015 04:27 PM
ahunt4
Sep 19, 2015 06:46 AM
AtholC
Sep 9, 2015 09:07 PM
