TRansmission whine
Old Mar 31, 2018 | 02:22 PM
Atlastajag1's Avatar
Default TRansmission whine
Perhaps I could get some feedback on the topic of transmission whine. I notice the whine on first thru third (maybe fourth). There is also a delay of between 1 and 2 seconds when shifting from Park to Reverse and also the opposite. Is this all normal on a 2005 XK8 with 63,000 miles?
Old Mar 31, 2018 | 03:11 PM
Jon89's Avatar
Neither of our ZF 6HP26 units whine at any speed or in any gear. Have you done an ATF drain-and-fill using a fluid that we know is appropriate (Mercon SP or Lifeguard 6)? Are you positive that your ATF is not low?
Old Mar 31, 2018 | 05:10 PM
Default Transmission whine
Hmm. That's disturbing. I would have preferred 'of course, they all whine like that'! Yes, the fluid was changed (or as much as could be drained and changed) at 60k, using Mercon SP. The pan / filter, as well as mechatronic gasket and cable connector seal was changed also. That was 2,000 thousand miles ago.
The specified 'temperature-in-short-order' filling method was used. There is no sign of fluid under the car, or where it is stored.
Jagg
Mar 8, 2020 10:53 PM
Anthony8858
Aug 9, 2016 08:21 AM
mcm97
Jan 5, 2015 12:54 PM
Jdub
Dec 24, 2013 10:13 AM
TomXJ8VDP
Feb 12, 2008 10:05 PM
