transmission "zzzzz" when it shifts
Old Dec 10, 2011 | 11:34 AM
sonicjohn's Avatar
Default transmission "zzzzz" when it shifts
What is causing the transmission in my '97 XK8 to make a "zzzz" sound when it shifts.
Old Dec 10, 2011 | 05:48 PM
Skid Mark's Avatar
Could be timing chain noise from the front of the engine due to weak tensioners. Mine sounded the same way at first, then progressed to making the sound whenever the engine was accelerating or shifting.
Old Dec 10, 2011 | 07:43 PM
randyb's Avatar
Where is the noise coming from?
Underneath you or engine compartment, left or right side or center.
Old Dec 11, 2011 | 11:44 AM
sonicjohn's Avatar
hard to tell where it's coming from . . . the car is moving and it does it when it is cold and shifting from 1-2,2-3,3-4.
Old Dec 11, 2011 | 12:56 PM
wheeble's Avatar
Transmission fluid a bit low I suspect. pull the plug and add a 1/4 qt of Mobile 1 synthetic atf and take it for a drive. the reason the noise goes away after it warms up is the fluid expands as it get warm.
Wheeble...
mobile 1 synthetic atf is compatible with your current fluid, no worries there.
Old Dec 11, 2011 | 06:19 PM
GordoCatCar's Avatar
Agree w/ Wheeble, my 97 sounded like that and it was a quart low on the ATF.
Old Dec 16, 2011 | 09:21 PM
jacassar's Avatar
Mmmmmm.... There is an additive that treats or solve transmission "whooping" during shifts (if that is your issue). Mainly a ZF tranny issue. I am not sure if it applies to 97 though... I think it started in 2004 on the Xj's. Worth investigating. Nice Car. Make sure you run nothin but synthetic in that NiKasil Engine & get those tensioners done or you may not have an engine by 100K....
aholbro1
Dec 29, 2024 06:46 PM
jaggedy
Nov 20, 2022 12:09 PM
Will P
Sep 19, 2018 08:36 AM
tsimms7
Sep 15, 2015 12:43 PM
AtholC
Sep 9, 2015 09:07 PM
