Trouble code P1111 question! 99XK8 - RESOLVED
Old Sep 14, 2018 | 04:04 PM
Rodkel's Avatar
Default Trouble code P1111 question! 99XK8 - RESOLVED
Emission problem is fixed, but after a few drive cycles, the code is still p1000. Is there a possibility p1111 is just not gonna show and that car will pass the test?
Last edited by GGG; Sep 16, 2018 at 10:20 AM. Reason: Add "RESOLVED" to thread title
Old Sep 14, 2018 | 04:20 PM
If P1000 is still reported, you have NOT completed all the OnBoard Monitoring tests. P1111 will be reported when ALL OnBoard Monitoring tests are completed.
As for "passing the test", with no indication of your LOCATION, it's impossible to say as requirements vary considerably around the World.
Old Sep 14, 2018 | 04:34 PM
motorcarman's Avatar
I live in rural North Central Texas and I do not live in a County that requires emission testing.
I really don't care if I have P1000 or P1111 logged in my ECM.
Just depends on where you live!!!!
bob
Old Sep 14, 2018 | 06:39 PM
avern1's Avatar
Another one of those with an important piece of information missing
Old Sep 15, 2018 | 02:54 AM
JagV8's Avatar
If my car kept having P1000 I'd read the status of the monitors to see which had not set then investigate in case it pointed to a problem worth fixing.
Here, we're not required to have P1111 i.e. all monitors or indeed any monitors set but I'd definitely want to know why I had P1000.
Old Sep 15, 2018 | 09:10 AM
Rodkel's Avatar
New Castle County Delaware
Old Sep 15, 2018 | 09:24 AM
max224's Avatar
There are drive protocols for each of the monitors which consist of driving at set speeds for set periods of time. My X-Type had the P1000 code and wouldn't go through PA inspection. I took it out on the highway and followed all of the various speed and condition requirements and got the P1111 code. Don't remember where I got the list of protocols, but I'm sure someone on the forum can provide them.
Old Sep 15, 2018 | 10:20 AM
OBD DIAGNOSTIC MONITORS
The six diagnostic monitors are as follows:
1. Heated Oxygen Sensors Monitor
2. Adaptive Fuel Monitor
3. Misfire Monitor
4. Catalyst Efficiency Monitor
5. Evaporative System Monitor
6. Comprehensive Component Monitor (Engine Management / Transmission)
The relevant Drive Cycles are as follows:
Old Sep 15, 2018 | 04:21 PM
Rodkel's Avatar
Thanks guys. I finally got the p1111 code. It took 5 cycles using the instructions you provided.
Old Sep 16, 2018 | 09:45 AM
JagV8's Avatar
Excellent! Thanks for the update.
Old Sep 16, 2018 | 10:21 AM
Good to hear it.
I've added RESOLVED to your thread title to help other looking for the solution.
Gus
Nov 13, 2016 11:39 AM
test point
Sep 29, 2010 10:21 PM
cole1072
Jul 15, 2010 08:09 PM
baz
May 8, 2008 02:24 AM
