True or False
Old Feb 11, 2010 | 09:53 AM
daddyo007's Avatar
Default True or False
After leaving the dealer to pick up a new battery, the dash flashed a yellow ASC for about 1 second. We have about 8 inches of snow on the ground and the streets are clear with some slick patches. I read the owners manual and is it true that while the trac control is active and there is any wheel spin the ASC will illuminate while the condition is present. There is no reason to be concerned other than this function is operating correctly.
I am somewhat dyslectic when it comes to reading and comprehending. Just want to be sure this is what it means.
Old Feb 11, 2010 | 10:41 AM
Paul Pavlik's Avatar
Completely Normal.
Old Feb 11, 2010 | 12:23 PM
Real_Tech's Avatar
Low battery voltage can also cause the traction fail message to flash during engine cranking.
Old Feb 11, 2010 | 05:50 PM
brgjag's Avatar
Normal assuming this post is not the issue. But he says CRANKING ENGINE, so assume that means starting.
Old Feb 11, 2010 | 08:00 PM
daddyo007's Avatar
Thank you for the info. The battery was new and up to full amp. I was driving not cranking the engine.
Johnken
Apr 8, 2018 10:21 AM
prettydaim
Nov 12, 2015 08:05 PM
k-man
Oct 5, 2015 08:09 AM
redxk8
Oct 4, 2015 08:28 AM
redgear
Sep 26, 2015 07:21 AM
