trunk release
Old Sep 23, 2012 | 01:45 PM
chopr's Avatar
Default trunk release
My trunk release will not work using the decklid button. The key will mechanically open the trunk, as will the dash mounted electric switch. Trunk lights go out when I push the latch mechanism with a tool. A simple test of the decklid pushbutton switch indicated a properly working switch. The ground is good at the decklid. I guess my next stop is at the security module? Have any of you resolved the same issue? Thanks in advance!
Old Sep 23, 2012 | 02:17 PM
RaceDiagnostics's Avatar
Here is how to fix the problem https://www.jaguarforums.com/forum/x...-button-74403/
Old Sep 23, 2012 | 04:51 PM
chopr's Avatar
My car has to have the same issue. Thanks very much! I will give that a look!
Old Oct 8, 2012 | 06:22 PM
Growl-R's Avatar
Originally Posted by RaceDiagnostics
I developed the same problem this weekend. I will give this fix a try!
Thank you!
Old Oct 8, 2012 | 11:32 PM
chopr's Avatar
Ok. I had a few minutes to remove that harness, and cut it open to have a look. Sure enough... one of the wires was completely separated. A second wire looked suspicious, so I cut it apart at the "bump", slid some heat shrink over the wires, and soldered both. I wrapped it all back up, and will install it tomorrow! Thanks VERY much for the tip! Incidently, I called my Jag parts dealer to see if they even had a harness, and they said they couldn't find the part number. Told me to just repair it. I see the number is right on the harness tag:"LJG3085AB" for my 2004. I thought it might be $25 or so. Ahem.... MSRP is $173.00!
Finbarr1975
Sep 5, 2025 08:38 PM
MrWhite
33
Oct 22, 2015 10:29 AM
adam699
Oct 13, 2015 05:53 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
