Tunnel connector
Old Nov 15, 2011 | 10:06 AM
scookexk8's Avatar
Default Tunnel connector
Does anyone know were the tunnel connector is located inside the car on a 2002 XK8. It's the main supply from the battery that feeds the rest of the fuse boxes.
Steve
2002 Blue Xk8 coupe
Old Nov 15, 2011 | 10:57 AM
Jag13cat's Avatar
Default Tunnel Connector
The tunnel connector, which I think you are referring to, is an eyelet connector in the transmission tunnel. The stud connector receives power from the High Power Protection Module and then provides power to the driver, passenger, engine compartment, and engine mgmt. fuse boxes.
Old Nov 16, 2011 | 08:20 AM
scookexk8's Avatar
Default tunnel
Jag13cat
That is the one I'm refering to, I tightened the nut next to the transmission. I,m trying to locate the other side that's inside the car. I want to make sure that one isn't loose also. I think I need to take the console out to get to it.
Thanks,
ScookeXK8
Finbarr1975
Oct 4, 2015 05:32 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
magmedia
Sep 28, 2015 09:49 PM
