Turning supercharger kit for the new Upgrade pulley
Old Dec 19, 2012 | 07:58 AM
User 070620's Avatar
Default Turning supercharger kit for the new Upgrade pulley
this is my invention to make a precise installation of the upgrade pulley.
Enjoy....
Attached Thumbnails Turning supercharger kit for the new Upgrade pulley-dsc_0035.jpg   Turning supercharger kit for the new Upgrade pulley-dsc_0040.jpg   Turning supercharger kit for the new Upgrade pulley-dsc_0041.jpg   Turning supercharger kit for the new Upgrade pulley-dsc_0053.jpg   Turning supercharger kit for the new Upgrade pulley-dsc_0048.jpg
Old Dec 19, 2012 | 08:56 AM
ccfulton's Avatar
Quite inventive.
Is this a tool that you invented or a novel adaptation of something that you already had?
I, for one, would be interested in pictures of the inside of the tool and how you mounted it to the S/C shaft to keep everything centered.
Thanks for sharing!
Old Dec 19, 2012 | 11:54 AM
Originally Posted by ccfulton
Quite inventive.
Thanks for sharing!
hi. yes, i invented this tool and i had doing all the pieces at lathe.
I will not show anything else because in Italy are the only one with this particular piece and see if some owners of Jaguar will want to do the work by myself.
copyright! :-)
the central axis exploits the internal thread of the shaft of the pulley
Old Dec 19, 2012 | 12:02 PM
WhiteXKR's Avatar
Would you be interested in making another and selling it? I would be interested in your price, as I also occasionally help others with upgrades.
Also, about how much time does it take to complete the cutting?
Old Dec 20, 2012 | 03:05 AM
[QUOTE=WhiteXKR;642127]Would you be interested in making another and selling it? I would be interested in your price, as I also occasionally help others with upgrades.
Yes, we can do this kit . i send you an private message for price.
After installing the kit, the job is ready in about 20 minutes to install the new pulley
Old Dec 21, 2012 | 09:15 PM
pomosv's Avatar
Good idea, simplifies the worst part of the pulley install process!
Old Dec 21, 2012 | 11:39 PM
Tirefriar's Avatar
I have a X308 XJR. I also want to uncork more potential out of my motor. Seems that a lot of people that upgrade their SC pulleys do the lower one mainly because they don't want to shave the snout. After seeing pictures (thanks Pomosv) its not bad at all. Plus with this here tool it should make things that much easier.
I would assume that the procedures would apply to the XJR as well?
White XKR, could the upper pulley be removed with a pulley puller? Or is the pulley remover/installer used by pomosv absolutely imperative to getting the job done correctly?
Old Dec 22, 2012 | 07:53 AM
WhiteXKR's Avatar
Yes, the XJR is the same.
You really need the very heavy duty puller made for this job due to the extremely tight friction fit. Alternatively, you can heat the pulley to red hot with an oxyacetyene torch or cut it off, but the puller is the cleanest soluton IMO.
I will rent my puller for a very nominal cost plus shipping if you decide to go forward.
Old Dec 22, 2012 | 07:59 AM
ccfulton's Avatar
Places like Autozone and O'Reilly's often let you rent tools. Basically you "buy" it as a deposit and get a refund when you bring it back.
It's a good solution for us shade tree types who don't use things like pullers and spring compressors every day.
Might be worth an inquiry at least.
Old Dec 22, 2012 | 08:29 AM
steveinfrance's Avatar
Very ingenious, a sort of longitudinal tank cutter.
Surprised you could get away with only one cutter and get such a good finish.
Old Dec 22, 2012 | 08:31 AM
WhiteXKR's Avatar
I have never heard of anyone having success with a standard pulley puller for this job. Either the puller will mangle or the old pulley will be deformed before it is removed. You also risk bending the supercharger shaft. You need to use a special puller designed for Eaton supercharger pulley removal. This tool also doubles as a pulley reinstallation tool.
Old Dec 22, 2012 | 08:38 AM
ccfulton's Avatar
Wasn't aware that it was an Eaton special tool, good to know.
Old Dec 22, 2012 | 08:41 AM
WhiteXKR's Avatar
Actually a number of companies make them, but they are purpose built for Eaton pulley removal.
Old Dec 22, 2012 | 10:07 AM
Brutal's Avatar
White is correct and beat me to it. You never ever use anything but the sc pulley tool, kenne bell and others do make them and not expensive. Especially compared to trashing the blower. I would either cut it off or remove the blower press the pulley off, machine the snout and install new new pulley along with new hoses under the sc. This is what i usually do and this tool would be great for a shop not looking to remove the sc or needing to do the hoses underneath. I would never recommend heat as to the potential damage from transferrance of too much heat into the snout bearings and seal. Patent it and sell them
Old Dec 22, 2012 | 12:37 PM
XKRacer's Avatar
I believe Lawson @ Powerhouse has done something similar
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
Saturbo
Sep 8, 2015 07:35 PM
Mike Green
Sep 7, 2015 12:39 AM
rachelstr
Sep 3, 2015 12:59 PM
