Underbody rust protection
Old Dec 21, 2020 | 07:45 AM
Bikergonebald's Avatar
Default Underbody rust protection
Hi,
I have a 2001 XK8 with only 63k miles that looks like it’s hardly been used in the wet but I will now be using it as a daily car so I won’t to get it protected against rust.
a local 4x4 specialist does underbody cleaning and wax oiling but they don’t do cavity or sill injection. The price is quite high at £450+vat.
based on the common rust points for these cars is it essentially to have cavity injection? The underbody all looks good but the rear subframe and suspension has a lot of surface corrosion.
thanks
kevin
Old Dec 23, 2020 | 01:36 PM
Markel's Avatar
l dont have a answer Kevin..........................but i was about to ask the same question myself. l want to cavity wax my 1999 convertible and was wondering where to drill, squirt and cap.
Old Dec 23, 2020 | 01:44 PM
I found a cheaper place that only does rust proofing and they’re about 40% cheaper. He seems to know a bit about these cars, asked if it was the steel or aluminium body and if it was a coupe or cabrio. He does do sills and cavity injection.
Old Dec 23, 2020 | 05:49 PM
Rust on the rear subframe is common. The subframe is substantial and it's more a case of being unsightly. The "A" Frame beneath it also rusts but it can fail as a result.
Have a look for threads by RaceDiagnostics for identification and rectification of most of the corrosion problems that can occur with the XK8.
jackals
May 4, 2019 08:04 AM
Andreas Pavlos
Dec 6, 2017 09:35 AM
Calhale
Jan 22, 2013 06:33 PM
SergeXJR
Jun 20, 2011 06:51 AM
pezzonovante88
Mar 28, 2011 07:18 PM
