uneven tire wear
Old Dec 1, 2014 | 08:16 AM
jjf's Avatar
jjf
Default uneven tire wear
what can cause tires to wear on the inside? I need to find/fix this, these are fairly expensive tires.
1998 XK8 conv
Old Dec 1, 2014 | 08:35 AM
Dennis07's Avatar
1998 XK8 conv
Alignment issues: negative camber or toe-out could do it. Either way an alignment check is in order.
Good luck.
Old Dec 1, 2014 | 09:05 AM
DaveInVA's Avatar
Bad lower ball joints can cause this also and it won't always show up on an alignment.
Dave
Old Dec 1, 2014 | 09:33 AM
tberg's Avatar
If shock mount bushings have deteriorated, there is not enough adjustment to do an alignment within specs as the front end sits too low.
Old Dec 1, 2014 | 10:24 AM
RaceDiagnostics's Avatar
Just to add to the list of possible causes, worn lower wishbone bushes can also cause this.
This trashed my tires in less than 1k miles, I was advised that they were a problem at my MOT and that I should get them replaced, I did the job myself 4 weeks later by which time the inner edge was down to the canvas.
Old Dec 1, 2014 | 11:13 AM
Poppyboy's Avatar
I just had this exact same problem. The cause was worn/perished upper and lower wishbone (control arm) bushings, anti-sway bar bushings and lower ball joints. I bought them all from Rock Auto and gave them to my mechanic to install. After replacing them, I got two lightly used tires, then an alignment.
Old Dec 1, 2014 | 11:48 AM
Jon89's Avatar
To those of you who have had to deal with ball joint / wishbone / bushing issues ruining your tires, did you experience premature tire wear on all four tires? Just the front tires? Just the rear tires?
Old Dec 1, 2014 | 01:30 PM
Poppyboy's Avatar
Only the front tires were negatively impacted, but I got a four-wheel alignment when all fixes were complete.
Old Dec 1, 2014 | 03:46 PM
frankc's Avatar
Take your car along for a free tracking check and I bet your camber is really out. First thing I would suspect is your bushes. Look up Powerflex. I have used them before and they have a lifetime guarantee, they do in the UK anyway.
hoodun
May 25, 2020 09:08 AM
jagxk2008
Feb 4, 2016 09:53 AM
FabCat
Sep 26, 2015 12:16 PM
kiddhan625
Sep 25, 2015 12:04 PM
Don R
Sep 14, 2015 12:34 PM
