Upper A Arm Shims
Old Apr 18, 2018 | 10:16 AM
Chuck Schexnayder's Avatar
Default Upper A Arm Shims
Replacing the upper Shock Mount and shock bushing. Would like to know correct way of placing the shims in the upper A arms bushing.
Was trying to hold shims in place during disassembling, but to no avail. They went all over the place and now I need advise on putting them in correct order.
Chuck
Old Apr 18, 2018 | 10:56 AM
dsnyder586's Avatar
There is a pdf online that covers it- its in this thread:
https://www.jaguarforums.com/forum/x...n-shims-81236/
Old Apr 18, 2018 | 12:10 PM
fmertz's Avatar
FWIW, I was able to leave the upper A-arm alone by removing the wheel well liner and angle the strut out and use the extra space by the firewall/purge valve. Tight fit, but it works...
Old Apr 18, 2018 | 01:02 PM
Ungn's Avatar
This is one of those things people stress a lot over but probably just doesn't matter.
One thin in front, 2 thick and one thin in back on both sides will probably work fine.
The explanation that the shims are to adjust caster for "road crown" (and, therefore the UK instructions are opposite) doesn't hold much water unless you are motoring your X100 down highly crowned country lanes (mine never has... I live in a Metroplex of 5 million people).
My X100 spends most of its time in the passing lane of 4 lane divided highways, so the adjusting for "road crown" has zero value as the crown is in the opposite direction.
Adjusting both sides for maximum caster does have value, because it improves straight line stability.
sanchez
May 8, 2019 07:45 PM
cat_fancier
Apr 11, 2017 02:37 PM
elmostro
Jan 18, 2015 07:43 PM
matjohns
Nov 26, 2013 08:01 PM
