Valley Hoses Gone Wrong
Old Jul 21, 2025 | 12:36 PM
XK8 SR UK's Avatar
Default Valley Hoses Gone Wrong
Hi All,
Hope the week is going well so far.
I am in the process of replacing my valley hoses due to a significant leak that just started from my 99 xk8.
All was going well, got the throttle body out and was about to remove the manifold with the elbow attached. Unfortunately this is where the good progress ended!
The fitted pipe from the right side was so brittle that even when disconnected it simply snapped off. This is the one that has the heat wrapper and goes to a quick connector leading to the wheel arch with two red buttons to disconnect. The first picture is the pipe still connected pre snap.
Can this pipe be replaced? What is it called and how does it connect to the elbow? As there seems to be no way to disconnect it from the elbow but all second hand elbow examples don't seem to have this pipe so that would indicate it is possible.
Secondly there is another fitted pipe from the other side of the elbow which does not appear to have any connections for disconnect. It has a stripe running the length of the pipe and disappears into a number of pipes under the coolant expansion tank. Anyone know how to remove this from the elbow so I can get the whole lot out? (Last picture)
Have tried googling this but there seems to be very little information or diagrams around this part of the car!
Thanks in advance for any assistance.
Scott
Old Jul 22, 2025 | 05:01 AM
XK8 SR UK's Avatar
Just to close this one off - the pipe is the Brake Booster Servo Vacuum Pipe / Tube (to Manifold) - It is a push fit into the elbow so when the outer ring is depressed it can be removed.
The other pipes are simple vacuum lines that time had sealed to the elbow, some gentle prying and these eventually came off.
Brake Booster Servo Vacuum Pipe / Tube (to Manifold) Part - MJA5910CB
Scott
Old Jul 22, 2025 | 10:43 AM
RaceDiagnostics's Avatar
Fyi
Jagbits Jaguar Parts: BRAKE BOOSTER VACUUM HOSE CONNECTOR KIT C2S15816 https://share.google/KUEtgJIOm5TzhhZl7
Old Jul 23, 2025 | 03:39 AM
XK8 SR UK's Avatar
Thank you
I also found this article on Jag repair which proved useful to understand the requirements for the connection
JagRepair.com - Jaguar Repair Information Resource
Scott
bocatrip
Apr 2, 2024 04:25 PM
pem1
Nov 23, 2023 04:39 AM
PeterG
May 17, 2018 12:10 PM
10 XF Premium
Dec 28, 2015 09:39 PM
Rhett
Aug 14, 2014 10:47 AM
