Valve Cover Gaskets
Old Aug 9, 2011 | 07:14 AM
JOEDUMBACH's Avatar
Default Valve Cover Gaskets
Can felpro valve gaskets v550 724r be used on 97 xk8?
Old Aug 9, 2011 | 08:56 AM
Paul Pavlik's Avatar
That set services the AJ27 Engine. The 97 XK8 uses the AJ26 Engine and a different Gasket Set.
Rock Auto does not list a set for the 97 XK8. You may have to go to the Dealer.
Old Aug 9, 2011 | 04:43 PM
Bamaman's Avatar
I think you've got the part # wrong--should be VS50724R. Rock Auto has it for a bargain $36.79--actually listed for Llincoln LS 3.9 engine. That also includes the spark plug hole gaskets.
I received a Rock Auto shipment today promptly for a Airtex fuel pump, pump screen and Wix fuel filter. The pump was $70--far less than $98 @ Autozone. As long as they carry a part, Rock Auto is usually cheaper--including the aluminum thermostat housing @ $43.
They're the giant of the mail order auto parts business.
Old Aug 9, 2011 | 06:56 PM
Correct. The part# should be VS50724R.
However, this is the set for a AJ27 engine and it will NOT fit a AJ26 Engine. The cross section of the seal is different and it will not fit in the Cam Cover Properly. And there are other differences.
silkcat
Jan 18, 2025 04:29 AM
xjrjag
Oct 24, 2024 03:09 PM
1964Daimler
Sep 9, 2015 11:20 AM
jaggermang
Sep 8, 2015 07:07 PM
philwarner
Sep 6, 2015 11:10 PM
