Vent with clock
Old Sep 8, 2014 | 08:49 PM
Jandreu's Avatar
Default Vent with clock
Anybody recognize this part, what model is it from. Need measurements.
1999 Jaguar Interior Vent Clock Wood Grain Dash Instrument Cover and Shift Knob | eBay
I have a. Nav car and want to swap my Nav screen for a new backup camera monitor but don't want to loose my clock. If this would fit my XK8 it would be the ticket.
Old Sep 8, 2014 | 08:55 PM
enderle's Avatar
Default 1999 xj-8
1999 Jaguar XJ XJ8 Dashboard Photos | GTCarLot.com
Old Sep 8, 2014 | 09:02 PM
giandanielxk8's Avatar
You'd probably need some custom woodwork done.
My dad has a VDP and, although I haven't compared measurements, the X308 vents and clock are longer overall than the XK8 vents. I might be wrong though.
Old Sep 8, 2014 | 09:18 PM
neatcat's Avatar
Good idea!
Some time ago i thought also about swapping the XK8-Vents for the XJ ones because of the clock - i have the nav-screen. Might be, that the overall dimensions are the same, as the vent openings themselves seem to be a little smaller than the XK ones.
Is there an XJ owner who would be willing to measure his vents? OK, might be the wrong forum :-)
Old Sep 8, 2014 | 09:24 PM
WhiteXKR's Avatar
Contact me if you want the backup camera to work with your existing nav. screen and keep the nav/clock functionality...I have a kit for that.
Jandreu's Avatar
Will post in the XJ board and see if anyone can advise. Thanks all.
Old Sep 8, 2014 | 09:26 PM
mjlaris's Avatar
Post back here when you find out. This is something I'd be interested in as well.
Mark
Old Sep 8, 2014 | 09:33 PM
Jandreu's Avatar
Thanks Steve, your system works great for integration but I already have a camera and separate monitor that will fit the same hole as the stock Nav screen so looking for a little cheaper solution than the converter and wiring hardness.
Might be coming your way if I can't cobble something acceptable together.
Old Sep 8, 2014 | 09:34 PM
Jandreu's Avatar
Mark
Will do, I just posted in the XJ board
Old Sep 8, 2014 | 11:52 PM
Chuck Schexnayder's Avatar
Default Vent w/ clock
Just checked my 2005 XJ8 and if they are the same size, it measures;
13 1/4 inches wide/Long
2 3/4 inches in height at a point across the face of the clock and then slowly tapers down to 1- 6/8 inches measured at the outside of the wind adjustment wheels.
Hope that helps.
Chuck
05/XK8 Conv and XJ8L
Old Sep 9, 2014 | 01:16 AM
Jandreu's Avatar
Hope that helps.
Chuck
Thanks Chuck, the 99 may be slightly different as it does not appear to taper, the size you gave is about 3/4 inch longer than my XK8.
Hopefully someone with an older model will chime in.
Old Sep 9, 2014 | 11:56 AM
Jandreu's Avatar
Well this was a good idea but a no go. Member on XJ board is reporting 360mm X 61mm that's about 14 1/2 inches long. My XK8 vent is 12 1/2 inches long..
Back to the drawing board
RedRider48
Oct 1, 2015 08:18 AM
jonahjob
Oct 1, 2015 07:54 AM
3jagfamily
Oct 1, 2015 01:49 AM
the guardian
Sep 25, 2015 03:06 PM
