Vvt question
Old Jul 14, 2017 | 09:34 PM
Mzpuzzy's Avatar
Default Vvt question
Does anyone have experience with the vvt and vvt selenoid on a 2000 xk8?
Old Jul 15, 2017 | 04:28 AM
run an advanced search of the XK8/XKR section using vvt as key word and you will find several posts regarding the vvt's
Old Jul 15, 2017 | 03:58 PM
motorcarman's Avatar
When you perform a search you should use the correct spelling of SOLENOID or you might also try ACTUATOR in the search terms.
The actuators are continuously variable with the AJ27 engine management.
The earlier ones just 'advance or retard'. (either/or)
bob
