VVT Seals
Old Apr 11, 2023 | 02:36 PM
Rex's Avatar
Rex
Default VVT Seals
Mine were replaced about a year ago and now one weeps! Is it possible to pull it out, clean and try re-installing with some kind of sealant? If so, how?
Old Apr 11, 2023 | 03:01 PM
fmertz's Avatar
You can definitely pull them out and check them. Cleaning them and the surrounding area would not hurt. Check if they already hardened or cracked. Sealant is always a tempting proposition but I always fear any excess will drop in and end up plugging up the wrong oil passage. I would personally replace them instead of taking my chances with a sealant. Your car. your call.
Best of luck, keep us posted.
Old Apr 11, 2023 | 03:25 PM
Rex's Avatar
Rex
How do you pull them? Undo the wire connector and pry out?
Old Apr 11, 2023 | 04:01 PM
Rex's Avatar
Rex
Very carefully just pry out the seal and clean all surfaces and just push it back in. When the weather improves, will take a run to see if it worked!
Todd Wiens
Apr 11, 2023 02:41 PM
drmike
Apr 6, 2023 08:25 PM
Jon89
Jan 17, 2022 03:07 PM
max224
Apr 23, 2020 03:39 PM
Jon89
Feb 12, 2017 03:26 PM
