Water pump replacement 4.0 4.2 x100
Old Nov 19, 2024 | 10:11 AM
brinny's Avatar
Default Water pump replacement 4.0 4.2 x100
Afternoon folks, as i go through the preventative maintence jobs on my car its thrown up a problem. Both are x100 versions , one a 4.0 1999 the other a 4.2 2003. Both supercharged. Can you tell me where i can readily find part numbers for these engines. I look on jaguar classic parts but it is a bit vague regarding the xkr. Anyone know off hand if the water pumps, thermostats and belts are the same on both cars?. Thanks for any assistance in advance.
Old Nov 19, 2024 | 11:40 AM
Silverjag0's Avatar
Same water pump same thermostat
I'm using US MOTOR WORKS US4124 pump 2 years no problems I paid 30$ iirc works fine
I would buy OEM thermostat or mahle , I tried motorad beck arnley they stuck close suddenly within 2 year
Old Nov 19, 2024 | 11:50 AM
brinny's Avatar
Great thanks. Would you know if the belts are also the same?
Old Nov 19, 2024 | 12:04 PM
Silverjag0's Avatar
4.2 engine require different belt bando or Conti works great
Beretta9
24
Dec 16, 2023 09:24 PM
bcruik
E type ( XK-E )
Jul 7, 2021 07:20 AM
Dan Boyle
Sep 28, 2018 08:01 PM
leadfoot4
Nov 8, 2017 04:47 AM
Bob OB
Jun 7, 2013 04:14 PM
