Water Pump or Thermostat?
Always boil the T-stat and make sure it opens before installing it. If you think the chances are so low it will happen to you - it has happened to me 3 times! A lot of bad ones slip through and then you start replacing everything else to avoid taking it to the dealer! Also the Jagbits Aluminum T-stat housing does not have the rib and all "correct" T-stats seem to fit.
Ozzy_UK
45
Feb 19, 2019 02:05 PM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
Oct 12, 2015 11:56 AM
